Rhino 9 - Rhino WIP New View with shadow
Hi, Can You please integrate in Rhino 9 a new View for a white model with the option of sharp and clean shading through sunlight? This shouldnt be so hard to make and heavy to load during the modelling process. I feel like every other software has this option except rhino and thats the only thing missing for me. It should have the option to export also only the shadow alone as a png (ViewCaptureToFile). If you have this feature I dont need any other softwares anymore and will definitely buy Rhino 9.
Hi Karim!
Welcome to this forum!
You can use Technical mode view and turn on shadows in it, tweak the settings to have sharp shadows.
On the “Light” panel, disable global illumination “Sunlight” and enable just the “Sun” light, and if you select it you can edit its direction and strength.
Consider making a copy of Technical view and edit that…
