Enjoying the new Rhino 9, however I’m finding the new mapping widget very difficult to use.
In previous versions, selecting “show mapping” would automatically select the widgets for all selected objects. It is now more annoying to manually select them, especially in crowded scenes.
More of a problem is that I can’t figure out how the widget is supposed to work now. Gumball, scale, or rotate tools no longer seem to affect them, only move. I am able to grab and use the grips for a single widget at a time, but very often I want to be mapping many objects at once.
Am I missing something with the new functionality? If not, I think the old was much more usable.
Hi @Susan_Jones ,
Can you share that 3dm or one that also shows the issue? I am not able to reproduce it here so far with single or multiple widgets. The main difference in v9 should only be that the color texture is now shown on the widget and can be made more or less transparent. You should still be able to adjust the widget as before. The MappingWidget and MappingWidgetOff commands will show and hide widgets for selected objects respectively. I’d like to see your file if possible to test here.
Yes - here is a simplified version of the model I’m working with: link
The brick material I was showing was from vray. I know the latest release is not optimized for Rhino 9 yet, so it’s possible there is an issue there. However I tried adding a generic rhino material (the grid above) and I’m still getting strange behavior. If it’s clear in the video above, it’s just seems…weird? The scale worked once or twice, but then wouldn’t, the gumball randomly deselects, scale 1d did not work (behaved like rigid was on, but wasn’t), etc.
Here is a simpler file that I started from scratch where I’m getting the same behavior. Concrete blocks are a vray material, grid is rhino. Scale seems to work once, but not again. Rotation does not work.
Thanks @Susan_Jones , I see the issue now and have filed https://mcneel.myjetbrains.com/youtrack/issue/RH-99994 for the developers. In the meantime, select only the wireframe of the widgets when transforming them entirely and the results should be as expected. It appears the selection of all corner points is what is causing the bug. I posted a video on the bug above which shows this.
