Rhino 9 - Linetype pattern extremely slow + array bug
@stevebaer
I just tested the new linetype pattern with 2 lines and 2 polylines (3 segments each) to make a cobble stone hatch. It works fine but is extremely slow for the display pipeline.
If I use Array with history then I get 3000 fps, but if I use the linetype pattern I get 12 fps.
And if I make multiple lines (25 in a 5x5 array) with this pattern then I get 2fps. Making it useless for work.
I made a simplified version here:
R9 Linetype pattern and array bug.3dm (403.6 KB)
Linetype geometry would be a huge win if the speed issue can be figured out since history is crap for this if I move the startpoint or alter the tangency of the start of the curve as this requires me to keep the initial geometry and have this positioned and aligned correctly for every single curve I want the pattern on. While linetype does this automatically.
I do wish for it to show the
I also think it would be great if when we select a curve with linetype geometry we see the initial curve selected and have the pattern shown in 50% transparent selection color (Yellow being default) This will make it much easier to adjust the curve.
Bug in Lock Children
Also note that LockChildren in history does not prevent me from selecting children. Nor does it prevent me from deleting them… And it doesn’t trigger the warning…
I don’t know if this got any attention so @jeff maybe you can look into why line type pattern is so slow?
Hei Jørgen -
This is on the list as RH-98780 Linetype patterns with geometry are extremely slow
RH-98780 is fixed in Rhino BETA
