Rhino 9 Feature : Instant Aliases (hot keys)
They don’t require you to hold a single key. No problem to utilize all possible commands types:
  • Holding a key for more than a set amount of time in milliseconds (typically 250-300 ms) OR taping it once and not doing anything else in the following moment (typically 250-300 ms) activates a quick alias, no matter of there is an active command or not.
  • Typing one or more letters activates a regular alias (outside an active command).
  • Typing the first letter of a possible Command line option during an active command, followed by Enter or RMB click, activates the corresponding option.
Tapping a key doesn’t activate an Instant Alias with a command active.
But it can be made to do so.
Which is what I requested a few posts earlier :wink:
@Trav did you manage to identify the issue as to why OptionsImport freezes Rhino and never resolves loading the options?
E: I’ve let Rhino process OptionsImport from a R9 (WIP) Export to R9 (WIP) for close to an hour now, to no avail. Importing from R8 is near instant.
I sure did, thanks for the files I could easily repeat the issue. RH-83873 I’ve got a ticket going and we’ll get the aliases importing working with the new changes.
@Trav Think I found the issue with the Aliases resetting, it’s the search field:
After using the search field and exiting out of the options, I only had the commands related to Join listed:
Also notice that this reset changed back the Instant Alias Delay back to 300 ms, which I set to 240 ms previously.
@Intuos thanks, I’ll take a look here as well.
@Trav here is a vid to help you reproduce the issue in (9.0.24261.12305, 2024-09-1) :
Notice that the Instant Alias for Join now seizes to work:
Also, please add the option to check all Aliases to be instant. Since the majority of my Aliases can be converted to be instant, this saves me 200 or so clicks.
Added here, RH-83876 Global checkbox to make all aliases “instant”
I just installed the latest WIP, and tried to import my V8 aliases. But that does not work. After I select the xx.txt nothing happens…
Hi Joerg -
Importing aliases not working is on the list as RH-83873 OptionsImport - Freeze
You can use OptionsExport in Rhino 8 and OptionsImport in the WIP, to import your aliases. The only thing that isn’t working is OptionsImport of a WIP OptionsExport. Note that the Alias Import and Export functions in the options menu appear to be removed.
We fixed the options importing yesterday along with the other small issues listed here.
Wish: Include an option in _ToggleInstantAliases (or introduce a separate command) where the delay can be enabled/disabled from the command line.
Hei Håvard -
Added to the list → RH-83907 ToggleInstantAliases - Delay Option
5 posts were split to a new topic: Instant Aliases for Rhino 8
RH-83907 is fixed in WIP
RH-83876 is fixed in WIP
A post was split to a new topic: Wish - retain transforms
