I’m trying to export a simple Rhino 9 Layout to DWG using _ExportLayout.
The drawing contains only native Rhino geometry: lines, hatches, and dimensions placed directly in Paper Space. No plugins are involved.
The exported DWG does not reproduce the original Layout correctly. The graphical representation differs, and the dimensions placed directly in the Layout are missing.
I’ve attached screenshots comparing the original Layout with the exported DWG, along with the sample files.
Is there an export setting I’m missing, or is this a limitation of _ExportLayout?
I also tried exporting the same Layout to PDF, which is explicitly listed among the available export formats. However, the resulting file cannot be opened in either Foxit PDF Reader or Chrome.
Is _ExportLayout intended to export the actual 2D representation of the selected Layout, or simply transfer its underlying model geometry and Layout structure? The current behavior seems inconsistent across file formats.
exported layout.zip (33.4 KB)
template-m.3dm (136.9 KB)
