Rhino 9 Crash on Rebuild
Rebuild a simple curve crashes Rhino.
Rebuild Curve.3dm (1.5 MB)
Rhino version: Version 9 (9.0.26300.09401, 27/10/2026)
Hi Chris,
Please run the SystemInfo command in Rhino and post the results. Not seeing the issue here
Rhino 9 SR0 2026-10-27 (Rhino 9, 9.0.26300.09401, Git hash:master @ b5c4aa079c11dd91ccd7b6aa067f5029f3fccf72)
License type: Commercial, build 2026-10-27
License details: Cloud Zoo
Windows 11 (10.0.26300 SR0.0) or greater (Physical RAM: 15GB)
.NET 10.0.2
Non-hybrid graphics configuration using DirectX
Primary display: NVIDIA GeForce RTX 3060 Laptop GPU (NVidia) Memory: 6GB, Driver date: 6-3-2026 (M-D-Y). DirectX(11)
Integrated accelerated graphics device with 4 adapter port(s)
  • Windows Main Display is laptop’s integrated screen or built-in port
Secondary graphics devices.
AMD Radeon™ Graphics (AMD) Memory: 1GB, Driver date: 10-25-2022 (M-D-Y).
Integrated accelerated graphics device with 5 adapter port(s)
  • Secondary monitor is laptop’s integrated screen or built-in port
DirectX Settings
Safe mode: Off
OpenBLAS: OpenBLAS 0.3.30 DYNAMIC_ARCH NO_AFFINITY Zen MAX_THREADS=64.
C:\Program Files\Rhino 9\Plug-ins\Commands.rhp “Commands” 9.0.26300.9401
C:\Program Files\Rhino 9\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 9\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 9\Plug-ins\RhinoAI\net8.0\RhinoAI.rhp “RhinoAI” 9.0.26300.9401
C:\Program Files\Rhino 9\Plug-ins\3dxRhino.9.rhp “3DxRhino.9”
C:\Program Files\Rhino 9\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 9\Plug-ins\UpdatesAndStatistics\UpdatesAndStatistics.rhp “UpdatesAndStatistics” 9.0.26300.9401
C:\Program Files\Rhino 9\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 9.0.26300.9401
C:\Program Files\Rhino 9\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 9.0.26300.9401
C:\Program Files\Rhino 9\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 9\Plug-ins\MeshCommands.rhp “MeshCommands” 9.0.26300.9401
C:\Program Files\Rhino 9\Plug-ins\Grasshopper2\net48\Grasshopper2Plugin.rhp “Grasshopper2” 9.0.26300.9401
C:\Program Files\Rhino 9\Plug-ins\RhinoCycles.rhp “RhinoCycles” 9.0.26300.9401
C:\Program Files\Rhino 9\Plug-ins\export_GHS.rhp “General Hydrostatics (GHS) Export”
C:\Program Files\Rhino 9\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino 9\Plug-ins\SectionTools.rhp “SectionTools”
Nothing jumping out here. Are you getting a dialog to submit a crash report?
Does the crash happen while in safe mode?
Yes I submitted a crash report. I don’t have the safe mode option
video evidence here: Unique Download Link | WeTransfer
You can see it doesn’t crash the first two rebuilds, but when I change the point count it does. I haven’t worked out what determines if it will crash or not.
Haven’t received the crash report yet. It takes a few minutes sometimes.
You can copy a shortcut and add this flag to open in safemode.
It crashes in Safe Mode also. Have submitted it as another crash report
Thanks, that at tells us a lot (not plugin related, and less likely to be graphics related)
Seeing a few similar reports via the crash system, but no open youtracks.
still trying to repeat in the latest.
Sending you a Release Candidate build to try (i’m running in the daily so still my differ)
No longer crashes in Version 9 SR1 (9.1.26307.03001, 03/11/2026).
Thanks for your quick response.
