Hello, I’m having some problems with texture maps in rhino 9.
If I copy and paste an item between 2 files with the same unit settings, it is changing or losing info. This example is some simple items with box mapping. When pasted into a rhino 8 file it comes in fine. Pasted into a rhino 9 file it is reverting to surface mapping. Other files have randomly kept some mapping, and lost other mapping. It also behaves strangely if i tell it to match mapping when one item works and the rest don’t.
The source file units are inches, the failure is when pasted into a target file that is inches, for some reason it works better pasted into a target file using milimeter units.
source file:
texture_test.3dm (3.4 MB)
pasted into r9
