Rhino 9 Brep | Plane Output Orientation/Seam Differs from Rhino 8
Running the attached Grasshopper definition in Rhino 8 and Rhino 9 produces section curves with different directions and/or seam locations.
The inputs are identical in both versions, but the output curves’ direction/start-point placement appears inconsistent between versions.
Is this an expected change to the intersection algorithm, or a regression? It affects definitions that rely on consistent section-curve orientation.
Rhino 8 version: Rhino 8 SR36 2026-10-20 (Rhino 8, 8.36.26293.11001)
Rhino 9 version: Rhino 9 SR0 2026-10-27 (Rhino 9, 9.0.26300.09401)
BrepPlane Compatability Regression.gh (515.8 KB)
Hi @Chris70,
Thanks for reported - I’ve logged a ticket so a developer can investigate.
– Dale
@Chris70 Could you provide some more context? Why do you need the seam to be where it is? I am not saying we cannot adjust this behavior but it would be helpful for me to understand more about what you’re doing.
The brep | plane intersection creates girdle curves which are then offset to create a bezel for a diamond to sit in.
In Rhino 9, the curves offset inwards or outwards seemingly at random, whereas in Rhino 8 they consistently offset in the same direction.
I can implement a check to ensure all curves offset in the same direction, but I didn’t see a reason why the behaviour should differ between versions.
Thank you, that’s helpful. I believe the offset direction has to do with curves getting reversed when they shouldn’t.
I am still not sure about the seam, though: do you need the start/end of the curve in the particular position that you’ve shown, or is just the issue with consistent offset direction of the curves?
The seam is used to dictate placement of prongs around the girdle curve. It is helpful when it is consistent like Rhino 8
