Rhino 9 beta won't start right after installation
Good morning. I tried to search for an existing topic that addresses my issue, but I couldn’t find one. I have just installed the Rhino 9 beta; when I attempt to launch it, it asks me to verify my email—which it does successfully, locating my license—but then, when it should open a browser window to complete the authentication process, it returns an error and closes without starting.
I am working on Windows 11, and I have tried the following steps:
launching Rhino Beta as an administrator
disabling Windows Firewall
disabling the antivirus
switching to a different internet network (LAN)
attempting to repair the .NET runtimes
I should also mention that Rhino 8 starts up normally using its cloud license.
@roberto.brondolo can you send us the installer name? (version)
EDIT: In addition, after starting the installer again, can you please try the “Repair” option? And report what happens.
Hi Giulio, thanks a lot. The setup version is rhino_9.0.26293.12303. I tried running the repair, which completed successfully, but unfortunately, the problem remains unresolved. The same setup worked perfectly on two other PCs; it seems that on this particular machine, Rhino is unable to open the browser to perform license authentication.
@roberto.brondolo at this point, another option is to call the support in Barcelona - contacts on this page.
EDIT: a licensing developer commented:
This looks like a proxy / VPN / anti-virus messing up the listener on
localhost.
The solution is to temporarily disable the proxy / VPN / 3rd party
anti-virus or make sure that they do not proxy `localhost` ,
`127.0.0.1`
These cases are very hard to diagnose because there are so many (invasive)
proxy / VPN / anti-virus products out there for Windows that it's impossible to
tell exactly what is causing the issue.
Solved!! The registry key “Computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\HTTP\Start” was set to 4 (disabled); changing it back to its default value (3) got everything working properly. This key is sometimes disabled to free up port 80 from local services.
