[Rhino 9 Beta] First selected curve in Blend isn't yellow
I’m writing to report a UI bug/issue regarding the Blend command in the Rhino Beta.
When using the Blend command, the first selected curve no longer highlights in yellow.
  • Previous behavior: The first selection turned yellow, making it very clear what had been selected so far.
  • Current behavior (Rhino Beta): The first selection doesn’t highlight in yellow at all, which creates confusion. I often end up accidentally selecting the same curve twice because there’s no visual feedback.
I originally thought this would be fixed quickly in an update, but the issue still persists in the latest build. Could you please look into restoring the yellow highlight for the first selected curve during the Blend command?
Thank you!
@Jean-Go thanks for reporting, it looks like Blend and BlendCrv both have this issue.
RH-97149 Blend and BlendCrv: highlight missing
Here too
RH-97149 is fixed in Rhino BETA
@Gijs @brian
rhino_9.0.26230.12303
BlendSrf works fine, but BlendCrv still isn’t working.
It wasn’t highlighted in yellow only the very first time, but now it’s working properly.
This is also an issue in the _Fillet and _Chamfer commands. The highlight of the first selected curve shows up just very quickly and disappears.
_BlendCrv does not seem to be fixed.
_ArcBlend has the highlight
In Rhino 8 it looks the same and overall I think it would be nice if the highlight was visible.
_TweenCurves for example also has a highlight of the first curve
_Fillet with the dynamic option, why is just the second curve highlighted:
Actually, I mentioned this earlier and then deleted it, but like BlendSrf, I think BlendCrv should keep the initially selected curve highlighted in yellow.
(I almost let it pass because it’s the same in Rhino 8.)
