Rhino 9 BETA: Display Optimizations
The latest Rhino 9 Beta (Oct 6 build) contains a ton of optimizations to help improve display performance. So far, many models in our testing pile are seeing massive performance improvements over previous versions of Rhino (often over twice as fast).
Optimizations are still being made. If you have models that you feel are too slow in Rhino 9, please let me know. I would love to see what could be done to make them display faster.
In the latest Rhino BETA, Direct3D delivers significantly lower viewport frame rates than OpenGL when navigating my large-scale city model (approximately 300 MB, with thousands of meshes and a wide variety of materials).
@ZHUO if this is a model you could share with us (https://www.rhino3d.com/upload) that would be great. Customer files like yours are very helpful in finding bottlenecks and making optimizations.
Edit: if this is the same model you already provided earlier, ignore the above
@ZHUO I think this might be because of
RH-99387 Absence of Dynamic Downgrade in Direct3d
I tested the latest beta with a 6.5Gb file composed of 642 automotive parts. It rotates, pans and zooms glass smooth. FYI… I have an Nvidia RTX A2000 12Gb graphics card. Switching to OpenGL sees a slight decrease in smoothness, but it’s still pretty impressive.
Nice work!!
Thanks for testing Dan; I also have @ZHUO’s model mentioned above and it looks like we can make a lot of performance improvements for that as well. Hopefully that will be speedy by next week’s beta.
@Gijs I didn’t add dynamic downgrade, but was also able to massively speed up this model in other ways. Once dynamic downgrade is in place it should just get even faster.
Yes I’m using the same model I submitted in RH-98334. As you mentioned, the absence of dynamic downgrade is probably one of the key factors here.
Glad to hear that Steve has already made some progress on this. Great work!
Hi @Gijs @stevebaer
I have a model made up of nested blocks. While I didn’t experience any issues in Rhino 8, in Rhino 9 some objects inside my blocks become invisible in shaded. I’ll share the file with you via the upload link.
Edit: I uploaded the file and the screen recording.
Edit 2: I found the source of the problem. This issue occurs when the alpha (opacity) value of some layers is lower than 255. I uploaded a new screen recording.
I can see the real improvement in speed, but, at the same time, I have the issue where tangent edges are displayed on non-transparent objects:
Both Direct3D and OpenGL.
SysINFO
Rhino 9 SR0 2026-10-6 (Rhino 9 BETA, 9.0.26279.06303, Git hash:master @ 38442ba6302a687894bfeb92efd4dd088e13993d)
License type: Commercial, build 2026-10-06
License details: Cloud Zoo
Expires on: 2026-11-20
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 16GB)
.NET 10.0.2
Computer platform: LAPTOP - Plugged in [77% battery remaining]
Non-hybrid graphics configuration using DirectX
Primary display: Radeon Pro 560X (AMD) Memory: 4GB, Driver date: 6-11-2025 (M-D-Y). DirectX(11)
Integrated accelerated graphics device with 6 adapter port(s)
  • Windows Main Display is laptop’s integrated screen or built-in port
Secondary graphics devices.
None found.
DirectX Settings
Safe mode: Off
OpenBLAS: OpenBLAS 0.3.30 DYNAMIC_ARCH NO_AFFINITY Haswell MAX_THREADS=64.
C:\Program Files\Common Files\McNeel\Rhinoceros\7.0\Plug-ins\Rhino 3DM File Version (aa091cb2-d8c0-4944-a17d-b66c80bec4ca)\7.0.7639.20582\RhinoFileVersion.rhp “Rhino 3DM File Version” 7.0.7639.20582
C:\Users\Piotr\AppData\Roaming\McNeel\Rhinoceros\Groupy.rhp “Groupy” 1.0.0.0
C:\Program Files\Rhino 9 WIP\Plug-ins\Commands.rhp “Commands” 9.0.26279.6303
C:\Program Files\Rhino 9 WIP\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoAI\net8.0\RhinoAI.rhp “RhinoAI” 9.0.26279.6303
C:\Program Files\Rhino 9 WIP\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 9 WIP\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 9 WIP\Plug-ins\UpdatesAndStatistics\UpdatesAndStatistics.rhp “UpdatesAndStatistics” 9.0.26279.6303
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 9.0.26279.6303
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 9.0.26279.6303
C:\Program Files\Rhino 9 WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 9 WIP\Plug-ins\MeshCommands.rhp “MeshCommands” 9.0.26279.6303
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 9.0.26279.6303
C:\Program Files\Rhino 9 WIP\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 9.0.26279.6303
C:\Program Files\Rhino 9 WIP\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse”
C:\Program Files\Rhino 9 WIP\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino 9 WIP\Plug-ins\SectionTools.rhp “SectionTools”
I’m seeing the problem here… I’ll get this tuned up…
Thanks,
-J
Hi @jeff
I think I’ve found a new bug; as you can see in the video, changing the alpha value causes the Z vector of the block base plane to become visible. The same problem is present in r8 as well.
I can’t repeat this here…
It looks more like the Z-Axis from the construction plane that’s also getting drawn on the block. What happens if you turn off “Show Z Axis” in your display mode? Do you still get the Z vector on the block?
Either way, this is pretty weird.
-J
This should be fixed in the next beta
I think I’ve found the source of the problem.
The fact that the grid is visible on top is causing this. However, other issues are also arising with the other settings. In other words, I want the grid to be visible on top of the objects.
RH-99519 is fixed in Rhino BETA
RH-99442 is fixed in Rhino 9 Service Release 1
