Rhino 9 BETA: Clipping Drawing Guide
There are three approaches to controlling how clipping drawings display properties, each with its own advantages and trade-offs.
1. From Input Object
Properties come from the input model geometry — if it’s set “by layer,” it uses all the by-layer or by-object settings on the input geometry.
Exceptions:
  • Hidden lines don’t inherit properties from the input; Hidden/Hidden Tangent is controlled by the output layer.
  • Silhouette also comes from the output layer.
  • Hatch color and print width for both the main hatch and boundary hatch come from the Section Style on the input layer or input object.
To use this method, turn off clipping drawings in details and set up the layouts directly.
Advantage:
  • What you see in the model is what you get in the clipping drawing.
Disadvantage:
  • You can’t map clipping drawing output to the standard layer properties in your template.
2. By Output Layer
Properties come from the output layer, except hatch pattern and thickness, which always come from the source (usually the Section Style). Note: the output layer can technically have a Section Style assigned, but it’s ignored — effectively useless.
Advantages:
  • You can set a standard print color and print width in the layer properties, which can be built into a template that follows drafting standards.
  • Every clipping drawing automatically follows that standard, independent of the input — the output layers enforce it.
  • Less layer management overall.
  • Object-level visibility control.
Disadvantage:
  • If you change inputs (e.g., the color of the layer the geometry sits on), it won’t affect the clipping drawing. In short, you can’t change model colors and have it propagate to the clipping drawings.
3. Use Source Layer
Very similar to “From Input Object” — what you see in the model is what you get in the drawing.
Advantages:
  • Like “From Input Object,” this respects by-object properties (e.g., an object on a yellow layer).
  • Changing layer color properties updates the drawing in real time.
  • No baking of object properties into the clipping drawings.
  • Maintains the true source-object-to-layer relationship.
Disadvantage:
  • You can’t turn off the model and still have the clipping drawing display.
Summary:
  • By Output Layer is best if you want consistent, template-driven standards regardless of the model.
  • From Input Object and Use Source Layer both give you real-time “what you see is what you get” behavior.
  • They differ in whether you can hide the model and still keep the clipping drawing visible.
  • Only “From Input Object” allows you to hide the model and keep the clipping drawing visible.
Comparison Chart
