Rhino 9 ArrayCrv
What have you guys done with this command? This used to be a very simple and quick command.
Draw an object, draw a line from start to finish, activate command, pick the line
type the distance or number of items and that is it
Now this full panel.
I am not sure if I’ve been doing the same thing for 19 years and cannot figure it out this new “feature” but this is absolutely shit. this new pannel is so useless and bad
The command needed new features. Also RH9 is WIP, so constructive criticism is usually more useful than ‘this is shit’.
I changed the category to Serengeti because this is about a change in Rhino 9 WIP.
A thread about the new ArrayCrv. Rhino WIP Feature: ArrayCrv
A post in that thread (not a rant) of how you use ArrayCrv and a simple explanation of why the new ArrayCrv does not work for you would be appropriate.
ArrayCrvOld is stil available and unchanged.
Thank you very much for all the comments and apologies for the lack of IQ I used to make this post, I was very frustrated in not finding answers and forgot my age when I made the post.
appreciate the prompt responses from everyone and once again apologies for the innapropriate language
No worries at all. The change is definitely a major disruption to the previous version and we knew the old command would need to stay for this reason. You can always explore the new version in your down time when timelines aren’t involved.
RH-95642 is fixed in Rhino WIP
