Rhino 8 wip section fills
I am using the latest and greatest. It is awesome. Love the push/pull. However the #1 new feature I’m looking forward to is section fills, especially for layout, and unless I’m doing something wrong, it doesn’t seem to work.
If you’re setting the section style on the clipping plane, then you need to set the objects section property to inherit its section style from that clipping plane. Object section styles are set to By Layer by default (like most object properties).
That’s it. Thank you
