with the newest version, Rhino crashes after first command (like drawing a box).
Work In Progress
(8.0.22109.8305, 2022-04-19)
Work In Progress
Hoi Filip -
I can’t find a crash report from you. Did you send in that report?
Also, does Rhino crash when you simply run SystemInfo
? If it doesn’t, please copy-paste that information here.
Hi Wim! I did send the crash report.
Here is the info I get when I run SystemInfo
Rhino 8 SR0 2022-4-19 (Rhino WIP, 8.0.22109.08305, Git hash:master @ 411144bf79a8d3f9172096d5e6bd59ccd416f32f)
License type: Commercial, build 2022-04-19
License details: Cloud Zoo
Expires on: 2022-06-03
Windows 10.0.22000 SR0.0 or greater (Physical RAM: 15Gb)
Computer platform: LAPTOP - Plugged in [99% battery remaining]
Primary display and OpenGL: AMD Radeon(TM) Graphics (AMD) Memory: 1GB, Driver date: 2-21-2022 (M-D-Y). OpenGL Ver: 4.6.14761 Compatibility Profile Context 21.30.40.09 30.0.13040.9001
> Integrated accelerated graphics device with 5 adapter port(s)
- Secondary monitor is laptop's integrated screen or built-in port
- Windows Main Display attached to adapter port #1
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 4.6 (primary GPU's maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60
Driver Date: 2-21-2022
Driver Version: 30.0.13040.9001
Z-Buffer depth: 24 bits
Total Video Memory: 512 MB
C:\Users\archi\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\Grasshopper2\2.0.8132-wip.36848\Grasshopper2Plugin.rhp "Grasshopper2" 2.0.8132.36848
C:\Program Files\Rhino 8 WIP\Plug-ins\Commands.rhp "Commands" 8.0.22109.8305
C:\Program Files\Rhino 8 WIP\Plug-ins\rdk.rhp "Renderer Development Kit"
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoRenderCycles.rhp "Rhino Render" 8.0.22109.8305
C:\Program Files\Rhino 8 WIP\Plug-ins\rdk_etoui.rhp "RDK_EtoUI" 8.0.22109.8305
C:\Program Files\Rhino 8 WIP\Plug-ins\rdk_ui.rhp "Renderer Development Kit UI"
C:\Program Files\Rhino 8 WIP\Plug-ins\NamedSnapshots.rhp "Snapshots"
C:\Program Files\Rhino 8 WIP\Plug-ins\Constraints.rhp "Constraints"
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoCycles.rhp "RhinoCycles" 8.0.22109.8305
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoCode\RhinoRoslyn.rhp "RhinoRoslyn" 8.0.22109.8305
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoCode\RhinoCodePlugin.rhp "RhinoCodePlugin" 8.0.22109.8305
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoCode\RhinoCPython.rhp "RhinoCPython" 8.0.22109.8305
C:\Program Files\Rhino 8 WIP\Plug-ins\Toolbars\Toolbars.rhp "Toolbars" 8.0.22109.8305
C:\Program Files\Rhino 8 WIP\Plug-ins\3dxrhino.rhp "3Dconnexion 3D Mouse"
C:\Program Files\Rhino 8 WIP\Plug-ins\Displacement.rhp "Displacement"
C:\Program Files\Rhino 8 WIP\Plug-ins\ConstraintsUI.rhp "Constraints UI" 8.0.22109.8305
I think I can run any command that doesn’t create geometry in Rhino. Also, I can open G2, but the moment I place a grasshopper component like ‘Mesh from Box’ Rhino crashes.
Switch the tesselation off, restart and try again.
That was a problem in my case (AMD card).
Piotr that worked, thanks!
Hoi Filip -
Yes, I’m afraid you are not necessarily going to get far with running Rhino 7 or 8 on that GPU.
Good to hear that you can at least keep running with tesselation turned off.
