Rhino 8 WIP Available Now!
Rhino 8 WIP (8.0.21236) is now available for Windows and Mac
Bugs Fixed:
  • Display: Silhouettes did not show in Technical mode (RH-65022)
  • Toolbar: Point size varied in some toolbar icons (RH-37466)
Enhancements:
  • File IO: SVG Export - Pays attention to linetype cap and join styles (RH-65287)
Features Added:
  • Ungroup: New UngroupAllNested command (RH-62546)
Rhino 8 WIP (8.0.21243) is now available for Windows and Mac
Bugs Fixed:
  • Divide: DeleteRemainder might delete the last segment when a curve can be fully-divided by a length (RH-65418)
  • File IO:
    • Figure out what is meant by SKP “group layers” and try to hook them up in SketchUp import. (RH-65420)
    • STEP Export failed to save to an external drive (RH-65417)
Features Added:
  • ArrayCrv: New Orientation=Stairlike option (RH-2913)
Windows-Only Changes
Features Added:
  • Display: Wish: Display pipeline method to draw curves with a linetype and scaling factor (RH-56716)
Rhino 8 WIP (8.0.21257) is now available for Windows and Mac
Bugs Fixed:
  • Annotation: Linetype: Pattern polycurves as a NURBs curve (RH-36465)
  • File IO: SketchUp Import - Empty tag/layer folder was imported (RH-65496)
  • Layout: linetype attribute for details (RH-3086)
  • MeshFromLines: Tuned up command prompt (RH-43779)
  • SDK: RhinoCommon: RhinoCommon does not support linetype table events (RH-65569)
Enhancements:
  • Bounce: Add a "Use Line" input option (RH-59765)
Features Added:
  • Annotation: Linetype: Print, PDF, and SVG export support cap and join settings (RH-1482)
  • Mirror: Added Object option that supports History (RH-65165)
Usability Problems Fixed:
  • Display: PrintDisplay: Leave out the details (RH-17124)
Rhino 8 WIP (8.0.21264) is now available for Windows and Mac
This build contains everything in Rhino 7.11 Release Candidate 2, and all the previous Rhino 8 goodness.
Rhino 8 WIP (8.0.21271) is now available for Windows and Mac
This build contains everything in Rhino 7.11 Release Candidate 3, and all the previous Rhino 8 WIPery.
Rhino 8 WIP (8.0.21292) is now available for Windows and Mac
Bugs Fixed:
  • Curve-curve intersection:
    • IntersectSelf: missing intersection (RH-65616)
    • SelSelfIntersectingCrv: fails, example (RH-62449)
    • ON_Curve::IntersectCurve missing many self-intersections (RH-52137)
  • UDT: Flow command ran out of memory when the base or target curve was a polyline folding back on itself (RH-8093)
Enhancements:
  • History: Symmetry works with cage editing (RH-7662)
  • UDT: Cage/CageEdit: Typing a number sets the same point count for all directions (RH-2046)
Features Added:
  • GrasshopperPlayer: Replace Rhino input (RH-60296)
SDK Enhancement:
  • DotNET: Added .NET 6 runtime support (RH-65460)
  • SDK: RhinoCommon: Exposed CRhinoLayerTable::DeleteLayers (RH-65951)
Mac-Only Changes
Features Added:
Bugs Fixed:
  • Python: rs.PropertyListBox fails (RH-36572)
  • Libraries: Context menu missing some icons (RH-65840)
  • SDK: Python:
    • Typo message and title swapped in PropertyListBox (RH-40294)
    • Did not find an existing file (RH-65935)
    • Mac 8.x cannot run Python scripts (RH-65928)
Bugs Fixed:
  • Toolbar: PackSubDFaces and SetPerFaceColorByFacePack commands had blank icons (RH-65828)
Rhino 8 WIP (8.0.21299) is now available for Windows and Mac
Bugs Fixed:
  • Curve-curve intersection: IntersectSelf command failed on a case (RH-37725)
  • Delete: Removing surface control points makes it rational (RH-66021)
  • Display:
    • Wires disappear when zoomed in (RH-65533)
    • Edges and Isocurves disappear when zooming in (RH-65019)
    • wireframe mode unreliable (RH-66027)
  • Mesh: NGons: Expose ngon functionality to get a vertex list for any/all boundaries instead of… (RH-32068)
  • Offset:
    • Innaccurate output example (RH-61921)
    • Offset produces incorrect result (RH-29910)
    • Kept wrong segments at sharp inner corners (RH-66029)
  • Pipe: Pipe miter fails (RH-52398)
  • SDK: SDK need a function to fit a NURBS curve through a set of points (RH-55239)
Bugs Fixed:
  • ClippingPlane: Isocurves are clipped on both sides When GPU Tessellation is disabled (RH-48326)
Enhancements:
  • Rendering: Decals: RDK: Toggle decal visibility (RH-61127)
Rhino 8 WIP (8.0.21306) is now available for Windows and Mac
Bugs Fixed:
  • Libraries: "Open containing folder" did not open the target folder (RH-65886)
  • PackageManager: PackageManager is broken (RH-65888)
Regressions Fixed:
  • Display: SetObjectDisplayMode doesn't work in Rhino 8 (RH-66149)
Rhino 8 WIP (8.0.21313) is now available for Windows and Mac
Includes everything in Rhino 7.13 RC 1 plus:
Bugs Fixed:
  • Core Architecture: Per layer/object hatch (RH-28717)
  • Split: Accept Percentage snap for Point option (RH-65989)
Enhancements:
  • ClippingPlane: Add Hatch option for Clipping Plane Fills (RH-53061)
  • ExtractSubCrv: Accept pre-selection (RH-66072)
Mac-Only Changes
Features Added:
Bugs Fixed:
  • CommandHistory: Give CommandHistory a toggle option? (RH-66192)
Rhino 8 WIP (8.0.21321) is now available for Windows and Mac
Bugs Fixed:
  • GetPoint: Zoom command incorrectly cleared percentage snap marks (RH-66296)
  • Inset: Failed on creased corners (RH-66258)
  • Join: Made an open curve with a closed region (RH-56877)
  • OSnap: Point objects on a ClippingPlane could not be snapped (RH-56697)
  • Rendering: Post Effect: Logarithmic tonemapping inconsistent output depending on scene (RH-63729)
  • RhinoCode:
    • numpy not installing (RH-66335)
    • Editor did not fit on the monitor (RH-66355)
    • Paths with space break the cpython install on windows (RH-66372)
  • Selection: Display incorrect after selecting objects via layer manager (RH-66292)
Enhancements:
  • Code Editor Control: Monaco: Support setting editor typeface and font size (RH-66351)
Features Added:
  • Line: Normal option failed to create a line from a linear curve (RH-66294)
  • RhinoCode: Make it possible to configure the code linting (RH-66280)
SDK Enhancement:
  • SDK: Added function that joins lines into polylines (RH-66286)
UI Change:
  • Grid: Command-line option "Extents" is renamed to GridLineCount (RH-54359)
Mac-Only Changes
  • ObjectCaptureFromPhotos: Should not be on the list of never repeat commands (RH-66337)
Bugs Fixed:
  • Rendering: Wrong viewport size in Document properties (RH-66265)
  • RhinoCode: Terminal window did not scroll (RH-66354)
Enhancements:
  • Layer: Added StatusBarLayerPaneWidth advanced setting (RH-48368)
Features Added:
  • ClippingPlane: Added "Object color" option for edge display (RH-29737)
Rhino 8 WIP (8.0.21327) is now available for Windows and Mac
Bugs Fixed:
  • Tween Curve "SampleNumber" Needs Clamping (RH-66430)
  • Rendering: Texture Mapping:
    • Paste command changes tile texture preview in Rendered mode (RH-66362)
    • Texture mapping properties layout (RH-66371)
  • ToNURBS: ToNURBS glitches on extraordinary vertices, valence 6, 8, etc… ("higher-order saddle points") (RH-62085)
Enhancements:
  • Annotation: Linetype: Works with dimension lines (RH-3076)
Features Added:
  • Grasshopper: Import 3DM - also import objects that are on hidden layers (RH-59775)
  • Grasshopper: Components: Grasshopper: Add ability to get SubD vertex tags to Rhino 7 Grasshopper (RH-66349)
  • Mesh: Added "by Naked" option to SelMeshEdges and ExtractMeshEdges commands (RH-66383)
  • OSnap: Geometry generated by ClippingPlane can be snapped (RH-39927)
Mac-Only Changes
Bugs Fixed:
    • Messages and error handling could be improved (RH-66404)
    • Canceled when switching focus to other document (RH-66425)
    • Unable to process paths containing spaces (RH-66403)
Enhancements:
  • ObjectCaptureFromPhotos: Progress now includes file import step (RH-66252)
Bugs Fixed:
  • RhinoCode: CPython init sometimes fails to write to config.json from multiple threads (RH-66394)
Rhino 8 WIP (8.0.21334) is now available for Windows and Mac
Bugs Fixed:
  • RDK: Hide IOR field when transparency is 0% in rhino custom material (RH-38733)
Mac-Only Changes
Regressions Fixed:
  • Preferences: Display Mode options page does not open (RH-66462)
Rhino 8 WIP (8.0.21341) is now available for Windows and Mac
Bugs Fixed:
  • File IO: SVG - Export Layers as Group Tags (RH-38196)
  • Layout: Method for creating new details (RH-2952)
  • Mesh: Deleting a mesh control point deleted, instead of dissolving, surrounding faces (RH-66485)
Crashes Fixed:
  • RhinoCode: crash opeing example (RH-66454)
Enhancements:
  • File IO: Export SVG - special case circles and arcs. (RH-59391)
Features Added:
  • ClippingPlane: Allows picking a clipping edge to select the clipped object (RH-66244)
Regressions Fixed:
  • File IO: SVG Export ignored hatches (RH-66466)
SDK Enhancement:
  • SDK: RhinoCommon: Added RhinoObject.ShortDescriptionWithClosedStatus method (RH-66427)
Mac-Only Changes
Bugs Fixed:
  • File IO: Paste SVG from the clipboard (RH-66434)
Bugs Fixed:
  • Rendering: Materials: Some labels in PBR detailed settings displayed black text in dark mode (RH-66478)
Rhino 8 WIP (8.0.21348) is now available for Windows and Mac
Everything in Rhino 7 SR14 RC1 is included, plus:
Bugs Fixed:
  • Groundplane: GroundPlane: Panel tune ups (RH-66477)
  • SDK: RhinoCommon: SweepTwoRail and Brep.CreateFromSweep() do the same (RH-55229)
Enhancements:
  • Sketch: sketch command needs internal undo- (RH-66610)
Mac-Only Changes
Bugs Fixed:
  • SDK: RhinoCommon: RhinoCommon: System.Uri not working (RH-66656)
Crashes Fixed:
  • RhinoCode: Editor doesn’t like it when the file is edited externally while open (RH-66399)
Rhino 8 WIP (8.0.21362) is now available for Windows and Mac
Bugs Fixed:
  • Displacement: Recalculated too often (RH-41599)
  • Selection: Control points not being pickable right after turning on (RH-66739)
Features Added:
  • Selection: Use object tree to improve picking speed and visibility test (RH-66500)
Mac-Only Changes
Bugs Fixed:
  • Toolbar: Flyouts all gone in RhinoWIP for Mac (RH-66758)
Rhino 8 WIP (8.0.22004) is now available for Windows and Mac
Enhancements:
  • TextField: Added BlockInstanceDescription function (RH-65750)
Rhino 8 WIP (8.0.22011) is now available for Windows and Mac
Includes everything in Rhino 7.15 RC1, plus:
Bugs Fixed:
  • Animation: Allow any display mode (RH-49948)
  • Annotation: Linetype: ExtractLineTypeSegments command kept input curves selected (RH-66906)
  • Display: Hard corners on thick lines (RH-33550)
  • File IO:
    • Odd curves in PDF export (RH-59559)
    • PDF Export: Arc shapes were not preserved like exporting to AI (RH-59999)
  • Print:
    • Support Arcs and Circles (PDF) (RH-44145)
    • Vector output connected lines in Hatch patterns (RH-66637)
  • Subobject Selection: Window-selection did not shade-highlight SubD faces (RH-66698)
  • VolumeMoments: Gave a different result with Blocks versus PolySrfs (RH-66540)
Enhancements:
  • TextObject: Wish: TextObject to group curves that make up a letter (RH-62135)
Features Added:
  • Annotation: DimVolume command (RH-66551)
  • Display: Added screen-space dashed curve drawing for Grasshopper (RH-59144)
Mac-Only Changes
Bugs Fixed:
  • Build Process: Debugging Rhino hung at splash screen (RH-66736)
Rhino 8 WIP (8.0.22018) is now available for Windows and Mac
Includes everything in Rhino 7.15 RC2, plus:
Bugs Fixed:
  • Annotation: Dot: Editing box did not get focused (RH-66498)
  • Autocomplete: Did not work when typing the RhinoCode command (RH-66266)
  • Displacement: Paste forces displacement refresh (RH-45807)
  • Display: Point clouds imported from PLY files were invisible (RH-66750)
Enhancements:
  • Selection: Ambiguous selection is made to highlight clipping sections (RH-66998)
Features Added:
  • Annotation: Added "Mask frame" option for annotation objects (RH-14110)
  • Display: Reflected Ceiling Plan (RCP) (RH-37076)
Mac-Only Changes
Bugs Fixed:
  • DotNET: Using C# component in GH crashed (RH-66916)
Bugs Fixed:
  • Code Editor Control: Monaco: Editor control closes autocompletion popup on windows (RH-66303)
Rhino 8 WIP (8.0.22032) is now available for Windows and Mac
Bugs Fixed:
  • Annotation: Hatch: Explode: Did not create boundary curves when hatch boundary was set visible (RH-66946)
    • List for object properties (RH-67183)
    • Dots pattern did not work with dimension lines (RH-66446)
  • Choose One Object: In Layout space, ambiguous selection misplaced highlight of block members in an inactive detail view (RH-67130)
  • Connections:
    • HorizontalConnection - unexpected results (RH-67226)
    • Added Vertical and Horizontal to creation menu (RH-66904)
    • Delayed on typing numbers (RH-67166)
  • CurvatureAnalysis: Lower value is set differently on the polysurface created by UseExtrusion=Polysurface (RH-66923)
  • Display: Original block instance was hidden while transforming (drag, move, scale…) in layout space (RH-67094)
  • File IO: Export scaled picture to DWG (RH-67223)
  • Layout: Per detail linetype scale (RH-2370)
  • OSnap: Snapping to points that did not exist (RH-67087)
  • Properties: Linetype override did not work (RH-67096)
  • Rendering: Materials: Selected material, instead of the one being right-clicked, was assigned to object (RH-67127)
  • RhinoCode:
    • TypeError using RhinoCommon methods (RH-66563)
    • Cpython has trouble resolving methods with out and ref parameters (RH-66400)
  • Selection: Curve with linetype would not select correctly after a kink was inserted (RH-65619)
  • SubD Symmetry: Joining SubDs with identical symmetries broke symmetry (RH-66415)
  • Toolbar: Toolbar editing - scroll to the current macro (RH-67176)
Enhancements:
  • ClippingPlane:
    • Sectioning properties (RH-67198)
    • Orientation is made consistent with Plane command (RH-56249)
  • Copy: Allows pressing Enter to copy from object bounding box center (RH-67162)
  • File IO: SOLIDWORKS Import - Supports up to version 2022 (RH-67085)
  • PointDeviation: Accepts SubD as object to measure (analysis mesh vertices are used) (RH-67195)
  • Properties: Added object level linetype scale setting (RH-66220)
  • RhinoCode: rhinoscriptsyntax needs cleanup to work with cpython (RH-66339)
Features Added:
  • ClippingPlane: Add selective clipping settings to object properties panel (RH-65801)
  • Connections: New command (RH-67238)
  • Connections: Allows selecting polyline segments without Ctrl(CMD) + Shift (RH-66897)
Mac-Only Changes
Bugs Fixed:
  • Annotation: Hatch: Did not display properly in Rhino WIP (RH-67035)
  • Display: Metal: no zoom window (RH-67000)
  • PrintPreview: "By Layer" Linetype Setting on Details Did not Preview and Print (RH-65695)
Bugs Fixed:
  • Annotation: Linetype: Object properties listed only one custom linetype (RH-67098)
Rhino 8 WIP (8.0.22039) is now available for Windows and Mac
Includes everything in Rhino 7.16 RC1, plus:
Bugs Fixed:
  • File IO: Import FBX meshes as SubD surfaces did not work (RH-67319)
  • Properties:
    • Object display and print colors did not update correctly (RH-67304)
    • Sectioning properties - UI updates (RH-67297)
    • Custom Mesh settings could not be disabled (RH-67286)
  • RhinoCode: editor: No default extension added to filename when saving a new script (RH-67287)
Enhancements:
  • Rebuild: Calculates maximum deviation when using a master curve (RH-66724)
  • StatusBar: Status bar pop up: show basic object type (RH-65846)
SDK Enhancement:
  • SDK: RhinoCommon: Added DrawHatch overloads for background fill (RH-67188)
Mac-Only Changes
Bugs Fixed:
  • File IO: Some file import options missing help button (RH-67126)
Bugs Fixed:
  • SDK: RhinoCommon: RhinoDoc.ActiveDocumentChanged was not called on Windows (RH-67298)
