Rhino 8 Windows_Dual Monitors_ShowEdges
The ShowEdges command launches the Edge Analysis window so far off screen it can’t be moved or used.
Hi Kevin - I am not sure I follow - can you see the dialog at all? Did it ever work for you in V8? What if you close Rhino, detach the second monitor then start Rhino?
