Rhino 8 window is totally black, no image
I just opened a drawing that I have been working on for some time and when R8 opens the windows are black with no image. I tried other drawings with the same result. I recently updated to Mac OS Tahoe.
Details about your specific mac model will probably be helpful. Is it Intel or Apple? What OS were you using when it worked? Did you also update R8 or is it the same version that previously worked?
It’s an iMac Intel i9. Nothing has changed except I installed Tahoe, but I did open the model since I made the OS cahange. The image has returned. I opened R7 to see if all versions were affected and it wasn’t. I went back R8 and the model opened.
Could you please run SystemInfo in the command line of Rhino8? then copy-past its output here? Thank you.
Sorry, I saw this too late and I have since moved to an M3Ultra machine and the problem seems to have gone away.
Thanks
