I downsize it before uploading for my sanity, here is the full resolution one.
Ah, got it. Thanks for testing and reposting. I donât downscale images before posting, discourse does it for me automatically. Then you have a smaller preview image and the original one for cases when it matters.
Hi Tay -
It looks like the crash bug was fixed a few hours ago - RH-77482 ViewcaptureToClipboard fails at 3x the resolution
The SSAO tiling issue with oversized view captures is on the list as RH-76018 (currently not public).
Thank you @wim
I confirm that the latest build resolved the 2 biggest issues the Missing SSAO and the Memory allocation crash, your team made a phenomenal job in resolving this pretty quickly.
the 2 remaining issues are
1- whenever there is an object with an assigned âPrint Widthâ value. it seems that the viewport capture shows extremely thickened lines whether the âprint previewâ setting is enabled or not.
The Result below shows the output with 3x viewport capture:
The second remaining issue is the âbucketingâ effect you get mostly in lines (like the thick lines above) but also happens when shading effect is set to parallel lines, like the below:
this is related to @lemberski 's post below:
Tiling bug using ViewCaptureToFile with parallel lines shading - Rhino - McNeel Forum
