Rhino 8 viewport and shading issues on AMD Radeon 890M
I’m using a GPD Pocket 4 with a Ryzen 9 CPU and integrated Radeon 890M graphics. Rhino 7 runs perfectly on this machine, and Rhino 8 was initially good (except for a printing issue that I scripted a workaround for), but has been increasingly unreliable over the past 3 to 6 months and is now consistently unusable, even on small files. I created a fresh empty template with a cube (my previous sanity test) and even this is no good anymore.
The issue(s):
  • Shaded views display incorrectly shaded with dark grey instead of correct colour
  • Points appear as solid squares, even when “round” is selected
  • Viewport performance is extremely poor
  • It used to be the case that when I open a Rhino 7 file in Rhino 8, it’s usually fine — but once I save it in Rhino 8 format and reopen it, the problems come back, but now I can’t even get this experiment to work. I used to think that it was the model because of this, but none of the other users in our organization have this issue (all of them are Intel and Nvidia graphics apart from me).
Checking the Video Hardware and Driver Info, Rhino 8 shows “Shading Language: Not supported”.
Things I’ve tested to try and pinpoint / resolve the issue:
  • GPU tessellation on and off
  • Every OpenGL slider setting
  • Custom and default display modes
  • Setting viewport sharpness and document mesh from a medium smoothness to fastest, to smoothest and back
  • Plugged in vs battery mode, and with different power profiles
  • VRAM allocation between, from 8 GB to 48 GB
  • Older builds of Rhino 8
  • Rhino 7, which remains completely stable and fast
At this point, I suspect the most recent AMD drivers have broken OpenGL GLSL support for this GPU, and Rhino 8 is falling back to a reduced graphics mode as a result.
Has anyone else seen this with recent AMD drivers or 780M/890M iGPUs? Is there a known good driver version? Any workaround that restores proper viewport behavior?
SystemInfo dump below for SR17:
Rhino 8 SR17 2025-3-7 (Rhino 8, 8.17.25066.07001, Git hash:master @ b14fcd901289f8715631debb308bc919a4988e07)
License type: Commercial, build 2025-03-07
License details: Cloud Zoo
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 56GB)
.NET 7.0.0
Primary display and OpenGL: AMD Radeon™ 890M Graphics (AMD) Memory: 8GB, Driver date: 11-6-2025 (M-D-Y). OpenGL Ver: 4.6.0 Compatibility Profile Context 25.11.1.251031
Integrated accelerated graphics device with 5 adapter port(s)
  • Windows Main Display is laptop’s integrated screen or built-in port
  • Secondary monitor attached to adapter port 1
  • Secondary monitor attached to adapter port #2
    Primary OpenGL: AMD Radeon™ 890M Graphics (AMD) Memory: 8GB, Driver date: 11-6-2025 (M-D-Y). OpenGL Ver: 4.6.0 Compatibility Profile Context 25.11.1.251031
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: None
Mip Map Filtering: Linear
Render version: 4.6
Driver Date: NA
Driver Version: NA
Z-Buffer depth: 24 bits
Total Video Memory: 64 MB
C:\Users\johandre\AppData\Roaming\McNeel\Rhinoceros\BlockEditNew\BlockEditNew_V8.rhp “BlockEdit” 1.0.0.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.17.25066.7001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.17.25066.7001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.17.25066.7001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.17.25066.7001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.17.25066.7001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.17.25066.7001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.17.25066.7001
And before when I used to be on SR24:
Rhino 8 SR24 2025-10-8 (Rhino 8, 8.24.25281.15001, Git hash:master @ ba28668a8431990c700173e46ef2dbcb873cf092) License type: Commercial, build 2025-10-08 License details: Cloud Zoo Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 60GB) .NET 8.0.19 Computer platform: LAPTOP - Unplugged [34% battery remaining] ~57 minutes left Non-hybrid graphics configuration. Primary display and OpenGL: AMD Radeon™ 890M Graphics (AMD) Memory: 4GB, Driver date: 10-13-2025 (M-D-Y). OpenGL Ver: 4.6.0 Compatibility Profile Context 25.10.2.251010 > Integrated accelerated graphics device with 5 adapter port(s) - Windows Main Display is laptop’s integrated screen or built-in port Primary OpenGL: AMD Radeon™ 890M Graphics (AMD) Memory: 4GB, Driver date: 10-13-2025 (M-D-Y). OpenGL Ver: 4.6.0 Compatibility Profile Context 25.10.2.251010 > Integrated accelerated graphics device with 5 adapter port(s) - Windows Main Display is laptop’s integrated screen or built-in port OpenGL Settings Safe mode: Off Use accelerated hardware modes: On GPU Tessellation is: Off Redraw scene when viewports are exposed: On Graphics level being used: OpenGL 3.3 Anti-alias mode: None Mip Map Filtering: Linear Anisotropic Filtering Mode: High Vendor Name: ATI Technologies Inc. Render version: 4.6 Shading Language: Not supported Driver Date: 10-13-2025 Driver Version: 32.0.22021.1009 Maximum Texture size: 16384 x 16384 Z-Buffer depth: 24 bits Maximum Viewport size: 16384 x 16384 Total Video Memory: 4 GB Rhino plugins that do not ship with Rhino C:\Users\johandre\AppData\Roaming\McNeel\Rhinoceros\BlockEditNew\BlockEditNew_V8.rhp “BlockEdit” 1.0.0.0 Rhino plugins that ship with Rhino C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.24.25281.15001 C:\Program Files\Rhino 8\Plug-ins\rdk.rhp “Renderer Development Kit” C:\Program Files\Rhino 8\Plug-ins\AnimationTools.rhp “AnimationTools” C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.24.25281.15001 C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render” C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.24.25281.15001 C:\Program Files\Rhino 8\Plug-ins\NamedSnapshots.rhp “Snapshots” C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.24.25281.15001 C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.24.25281.15001 C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.24.25281.15001 C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.24.25281.15001 C:\Program Files\Rhino 8\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse” C:\Program Files\Rhino 8\Plug-ins\Displacement.rhp “Displacement” C:\Program Files\Rhino 8\Plug-ins\SectionTools.rhp “SectionTools”
Anybody else have the same issue?
Did you try running Rhino 9? I’m curious if running it with DirectX (which is currently the default in Rhino 9) works better for you.
To figure out if this is due to an update of Rhino 8, or an update of your drivers, I guess the only way to find that out is to install a Rhino 8 SR from 6 months+ ago and see if that makes any difference. If you are willing to test this (You’ll have to uninstall the current Rhino 8 to install an older version of Rhino) I can send you an older build by pm.
Hi Gijs, hope you had a Merry Christmas and good start to the new year. I just installed Rhino 9 and it works with (almost) no problems so far.
OpenGL for some reason has none of the issues I have seen on Rhino 8 - shaded is displaying correctly:
DirectX however, shows some ghosting or draw order issues. There are guidelines and snap points inside the solid geometry of the parts that should not be visible in shaded view. See below:
Rhino 8 looks like this on the same PC, just for reference:
@wortley.jb
Can you go to Display Modes in your settings and export the mode you are using (.ini) in Rhino 8?
I want to see if there is anything that is messed up in the mode that causes this.
AFAIK OpenGL in 8 and WIP should not be that different.
Direct3D is still heavily in development so it’s good to get feedback where the wheels fall off. If you could share a (minimal) example file that shows the issue that would be most welcome.
Hi @Gijs and @wortley.jb I saw this thread and thought I’d follow up here, I bought a new laptop with the same integrated graphics card (AMD 890M) and having similar display issues. Wondering if you’ve found a workable solution in the past few months? I’m running the latest Rhino8, which is causing downgraded/blocky graphics while orbiting in rendered/arctic mode. See attached screenshot. I tried Rhino 9 as recommended (direct3D and OpenGL) and got the same result. Have either of you discovered another workaround on the Rhino or GPU side? Happy to provide info or help troubleshoot.
Arctic.ini (14.1 KB)
Thanks
Matt
