Hi everyone!
I’m experiencing an issue with Rhino 8 SR35 where the viewport titles (Perspective, Top, Front, Right) disappear as soon as the startup screen closes.
System:
Rhino 8 SR35 —
8.35.26251.13001 -
Windows 11
NVIDIA GeForce RTX 4060 Laptop GPU, 8 GB
Latest NVIDIA driver installed
What I’ve tested:
ShowViewportTitlesis enabled. -
Restored the default window layout.
Switched between Light and Dark appearance themes.
Disabled GPU Tessellation.
Updated the NVIDIA driver.
Tested Windows windowed-game optimizations and the high-DPI scaling override.
Reinstalled Rhino 8.
Findings:
Viewport titles appear correctly in Safe Mode.
Titles remain visible when OpenGL is set to software rendering (level 0).
With hardware acceleration enabled (OpenGL 4.6), the titles disappear after startup.
Resizing or minimizing/restoring the Rhino window makes the titles flicker and briefly become visible. (Almost like glitching when I aggressively resize the window)
The issue occurs in both blank documents and existing
.3dmfiles.
Could this be a graphics/UI rendering issue in SR35? What diagnostic steps would you recommend?
(Also when opening rhino and its starting up i can see the titles in the background but as soon as the startup panel disappears so do the titles)
Thanks.
