New Rhino 8 is much faster in 3D view (except ghosted where regularly crashes) but the interface is very slow. For example, typing the name of a layer in the search field takes 3-5 seconds to work. Snap options are also very slow (1-2 seconds). I have a fast i9 computer with 64Gb, SSD, new graphics card with the latest drivers. Can I do something regarding the slow interface or it is a bug that will be solved?
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 64Gb)
.NET 7.0.15
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 3060 (NVidia) Memory: 12GB, Driver date: 10-26-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 546.01
Secondary graphics devices.
NVIDIA GeForce GTX 970 (NVidia) Memory: 4GB, Driver date: 10-26-2023 (M-D-Y).
> Accelerated graphics device with 8 adapter port(s)
- Secondary monitor attached to adapter port #0
> Accelerated graphics device with 0 adapter port(s)
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 10-26-2023
Driver Version: 31.0.15.4601
Z-Buffer depth: 24 bits
Total Video Memory: 12 GB
C:\Program Files\Scan&Solve Pro for Rhino 6 & 7\SnSPro_Rhino_6+7.rhp “Scan&Solve Pro for Rhino” 1.0.0.0
C:\Program Files\Geometry Gym\Rhino8\ggRhinoIFC.rhp “ggRhinoIFC” 2.1.22.0
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V6\VRayForRhino.rhp “V-Ray for Rhino”
Hello Igor,
I think i face the same problem with Rhino 8 . A massive delay when enable or disable or just ticking the modeling aids (filter, osnap, gumball etc,).
Is it possible to solve this?
Thanks in advance
Panagiotis
Hello Wim
Thanks for the reply,
Usually happens in files with objects in it (for example in a file 100MB), not in empty files.
When tick for instance the end osnap the tick icon appears in the box after 1 second. As you can realise its impossible for me to work properly.
I send you the System info
Windows 10 (10.0.19044 SR0.0) or greater (Physical RAM: 32Gb)
.NET 7.0.15
Primary display and OpenGL: NVIDIA GeForce GTX 1060 6GB (NVidia) Memory: 6GB, Driver date: 6-8-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 536.23
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 6-8-2023
Driver Version: 31.0.15.3623
Total Video Memory: 6 GB
C:\Users\user\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\NVIDIADenoiser\0.4.3\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.3.0
I think I need a sample file that shows this behavior. Pls upload it here
I made a test file with 1300 layers and search is still snappy. I do see a delay when all layers start with the same name, e.g. layer_###, and then typing layer will be slow.
