Rhino 8 Service Release Candidate Available
Rhino 8 SR20 Release Candidate 1 for Windows and Mac (8.19.25133) is now available
To get it, subscribe to the Release Candidate update stream.
Requires Rhino 8
Bugs Fixed:
  • ser text: Paste to inactive cell (RH-87263)
  • CPlane: Auto CPlane conflicts with OneView (RH-87056)
  • CurveBoolean: Should temporarily disable Grid Snap (RH-87124)
  • Display:
    • Grasshopper CenterMark Preview is Clipped (RH-87187)
    • Issue with clipped SubD objects (RH-82133)
    • Clipping fill incomplete (RH-81289)
    • Rough sub-object highlight on Mac (RH-87078)
  • Export: Ordinate dimension adds extra text when exporting to .dwg (RH-87383)
  • File IO: DWG: Import DXF inconsistencies in block with text (RH-84045)
  • Import: Dimension Text Height Not Importing Correctly (RH-87002)
  • Isometric: Causes perspective to go nuclear (RH-87009)
  • Layer: Resetting layer filter clears selection (RH-87301)
  • NamedSelections: Delete UI performance issue (RH-86766)
  • Print:
    • Vector Outputs Square Hatch Points, Not Round (RH-86281)
    • Corner vertices are visibly and larger (RH-84253)
    • ‘Print Multiple Layouts’ may not preview (RH-87095)
  • Properties: Button behind layer dropdown is activated (RH-87230)
  • PushPull: Does not work for certain flat surfaces (RH-87208)
  • Rendering: Cycles: Picture self-illumination broken (RH-86111)
  • ScriptEditor:
    • Completion does not work in string interpolation (RH-87258)
    • #load with no space between # and load does not work in C# (RH-87073)
    • Autocomplete does not show files linked using #load (RH-87074)
    • Code completion incorrect (RH-87123)
  • SDK: Support plug-in overrides for double click behaviour (RH-87007)
  • SDK: RhinoCommon:
    • Rhino.Geometry.Brep.Unroller Explodes Brep Unexpectedly (RH-87303)
    • RhinoDoc.Groups.GroupMembers(int index) does not work with headless doc (RH-87223)
  • Viewports: Lens length decreases when toggling view projection between Perspective and Parallel (RH-86523)
  • What: Shows Text info for Point Clouds (RH-87142)
Crashes Fixed:
  • File IO: Exporting any mesh as obj crashes (RH-87315)
Enhancements:
  • File IO: Supports reading SolidWorks 2025 files (RH-87219)
  • Layer: Allows setting all layer properties (except materials, linetypes, and section styles) of reference layers from linked blocks (RH-68718)
Features Added:
  • OSnap:Mid: When only midpoint is enabled, moving mouse cursor near any part of a curve would snap to its midpoint (RH-86927)
Regressions Fixed:
  • -Import command can no longer process gh files. (RH-87156)
  • Export: Saving to DXF regression (RH-87322)
  • File IO: Export OBJ Crashes (RH-87058)
  • Print: Messy Vector Print from Intersecting Objects (RH-86993)
  • SpaceMouse: Does not select properly (RH-87017)
SDK Enhancement:
  • SDK: RhinoCommon:
    • DrawMeshShaded() small wish (RH-87384)
    • Backface Setting: Single color for all objects (RH-86440)
    • Exposed ON_Brep::LoopIsSurfaceBoundary (RH-86960)
Usability Problems Fixed:
  • ScriptEditor: Script editor should autocomplete code params (RH-85076)
Mac-Only Changes
Bugs Fixed:
  • CommandHistory: Command popover causes wrong document to be key after Cmd + N (RH-83106)
  • Grasshopper: TTToolbox crashes Rhino (RH-87049)
Windows-Only Changes
Bugs Fixed:
  • SDK: RhinoScript: SelectLayers Null argument not working in Rhino 8 (RH-87065)
Rhino 8 SR20 Release Candidate 2 for Windows and Mac (8.19.25140) is now available
Requires Rhino 8
Bugs Fixed:
  • File IO:
    • Dimension Text Height Not Importing Correctly From DWG Files (RH-87002)
    • Brep fails to export to SKP (RH-87464)
  • StatusBar: Status bar units are wrong (RH-86732)
Regressions Fixed:
  • MeshOutline: Broken in 8.20 (RH-87452)
  • SDK: RhinoCommon: DisplayPipeline.DrawText regression (RH-87220)
SDK Enhancement:
  • SDK: RhinoCommon: Allows setting single-color backface for all objects (RH-86440)
Mac-Only Changes
Regressions Fixed:
  • Display: Render mesh broke for some mac users in 8.20 (RH-87449)
  • Intersect: Intersection of two spheres is partial curve not full circle (RH-87538)
Bugs Fixed:
  • Rendering: Vray rendering of mesh effects broke (RH-87529)
Rhino 8 SR20 Release Candidate 3 for Windows and Mac (8.19.25147) is now available
Requires Rhino 8
Crashes Fixed:
  • Annotation: Leader: Crash on creating 17th leader (RH-87550)
Rhino 8 SR21 Release Candidate 1 for Windows and Mac (8.21.25161) is now available
Requires Rhino 8
Bugs Fixed:
  • Annotation: Styles: Annotation Style: Annotations not updating when Fit Arrow dropdown is changed (RH-87650)
  • Block:
    • Instance Rotation Properties - Feet and Inches (RH-87645)
    • AddMissingBlockAttributeKeys command - AllBlockInstances ignores invisible block instances (RH-87605)
  • ClippingPlane: Polyline features get obscured by clippingplane (RH-83784)
  • Display:
    • SubD analysis mesh doesn’t transform (RH-87382)
    • Segmented Linetype Quality Issue (RH-84564)
  • Document UserText: Tab key gets sent to command-line (RH-87722)
  • File IO: Models in decimeters export to STP as meters (RH-87469)
  • Grasshopper: Preview of Annotation Dot in viewports is not interactive (RH-87428)
  • LineTypeDisplay: Size of dots does not match width of segments (RH-86870)
  • Make2D: Hidden lines missing (RH-50127)
  • MeshSplit: MeshSplit test case (RH-81394)
  • OffsetMesh: Incorrect offset direction (RH-87229)
  • RDK: Mouse wheel scrolling stuck in Texture Mapping properties (RH-87432)
  • ScriptEditor: Roslyn runtime always extracts netfw ref assemblies (RH-87539)
  • SDK: RhinoCommon:
    • Unable to replace LightObject ObjectAttributes (RH-87445)
    • Line.MinimumDistanceTo gives incorrect result for co-linear lines (RH-87573)
    • ShrinkWrap() with CancellationToken is missing from PointCloud and IShrinkWrapService (RH-87443)
  • StatusBar: Inches are Shown as Feet (RH-87173)
  • SVG Editor: Import clears file prematurely (RH-87575)
  • ViewCaptureToFile: ViewCapture.CaptureToBitmap captures with small border (RH-87393)
Enhancements:
  • Block: Added AllBlockInstances option to AddMissingBlockAttributeKeys command (RH-87487)
  • PropertiesPage: AlwaysShowGeneralObjectProperties Setting (RH-86628)
Regressions Fixed:
  • BackgroundBitmap: .pcx format not supported (RH-87433)
  • OffsetCrvOnSrf: Does not extend if the surface is trimmed (RH-84888)
SDK Enhancement:
  • SDK: RhinoCommon: Expose CDisplayAttributeMaterial properties (RH-87592)
UI Change:
  • Units: Renamed 'Units per meter' to 'Meters per Custom Unit' in document properties (RH-87565)
Mac-Only Changes
Bugs Fixed:
  • ChangeLayer: Layer: Crv Points Issue on Locked Layers (RH-87446)
  • Linetype: Change Doesn't Stick (RH-87598)
  • MatchSrf: Settings need to use point as decimal separator when comma is set for system (RH-87342)
  • PrintPreview: Raster Preview Not Showing Contents of Details (RH-86271)
  • Properties: Pressing Enter after changing object properties doesn't bring focus back to command-line (RH-87366)
Crashes Fixed:
  • Grasshopper: Crash When Copy String to Clipboard (RH-87235)
Regressions Fixed:
  • Intersect: Only part of a circle is created between two intersected spheres (RH-87538)
Bugs Fixed:
  • Display: Curve drawing quality (RH-78744)
  • PrintPreview: Detail Contents Previewed Too Thin as Raster (RH-86273)
  • SDK: Removing unimplemented CRhinoDib::ToON_WindowsBitmap (RH-87563)
  • SVG Editor: File > Close does not close SVG Editor (RH-87557)
Crashes Fixed:
  • Display: Turning Off Clipping Plane Crashes (RH-87801)
Rhino 8 SR21 Release Candidate 4 for Windows and Mac (8.21.25176) is now available
Requires Rhino 8
Rhino 8 SR22 Release Candidate 1 for Windows and Mac (8.22.25189) is now available
Requires Rhino 8
Bugs Fixed:
  • Annotation: DimAngular: Fails in Ortho View (RH-87736)
  • Annotation: DimLinear: "Object" Only Dims a Segment (RH-88092)
  • Annotation: Hatch: Boundary mode causes history update bug and memory leak (RH-87915)
  • ChamferSrf: Failure sample (RH-80860)
  • ContinueCurve: Resulting curve fails with area calculation (RH-87917)
  • Display:
    • CaptureToBitmap() antialising with transparent background wrong (RH-88256)
    • FFO Custom CPlane Widget Messes Up Display (RH-87877)
    • Linewidth Preview is Zoom-dependent (RH-87911)
  • Extend: Extended Line is Segmented (RH-88091)
  • Import: Attributes in DWG Import Incorrectly (RH-87836)
  • Layer: Canceling search in Layers panel expands layers (RH-80834)
  • PackageManager: Yak CLI uses the wrong install directory on Mac (RH-88110)
  • SDK: RhinoCommon:
    • RhinoCommon: OpenNURBS: opennurbs_dimension.cs: AdjustFromPoints overload ignores rotationInPlane (RH-87973)
    • OpenNURBS: opennurbs_3dm_settings.cs: AnimationName and HtmlFileName properties are nearly identical (RH-87936)
    • OpenNURBS: opennurbs_3dm_settings.cs: ModelLocationIsSet returns value base on EarthLocation (RH-87935)
    • OpenNURBS: opennurbs_3dm_settings PageAbsoluteTolerance setter sets relative tolerance (RH-87934)
    • OpenNURBS: opennurbs_arc.cs Angle property summary is potentially misleading (RH-87940)
    • OrdinateDimension.LeaderPoint Bug (RH-87909)
  • Selection: Finds duplicates when ClippingPlane is active (RH-88177)
  • StatusBar: Changing layer also clicks on panel behind (RH-87718)
  • Templates: Thumbnail missing for Small Objects - Inches (RH-88043)
  • Trim: Grouped objects on hidden or locked layers can still trim objects (RH-88141)
Crashes Fixed:
  • Toolbar: Crash when creating a button (RH-88056)
Enhancements:
  • Grasshopper: Loft & Extrude Point issues (RH-85485)
  • Layout: Allows 3 decimals in width and height (RH-87871)
  • SelChain: Prefers segments of the same type (curve or edge) as the first picked segment (RH-88270)
Regressions Fixed:
  • Properties: Layer dropdown loses focus when resized (RH-88003)
UI Change:
  • Toolbar: Added Grasshopper help button to Grasshopper toolbar (RH-87327)
Mac-Only Changes
Crashes Fixed:
  • RDKCrash: Crash after internal Metal error (RH-78648)
Bugs Fixed:
  • Display:
    • Worse curve drawing quality, especially with high-contrast colors (RH-78744)
    • Curves Don’t Display Smooth (RH-86693)
Crashes Fixed:
  • Toolbar: Rhino crashes when moving a button (RH-87533)
Rhino 8 SR22 Release Candidate 2 for Windows and Mac (8.22.25196) is now available
Requires Rhino 8
Bugs Fixed:
  • SDK: RhinoCommon:
    • OpenNURBS: opennurbs_extensions.cs: Potential bug in ReadApplicationData method (RH-87994)
    • OpenNURBS: opennurbs_bezier.cs: GetBoundingBox accurate parameter ignored (RH-87942)
  • Selection: Wrong verbal feedback when removing from selection (RH-88294)
Rhino 8 SR22 Release Candidate 3 for Windows and Mac (8.22.25201) is now available
Requires Rhino 8
Bugs Fixed:
  • Developer Tools: Some RhinoCommon targets should be in buildTransitive in nuget packages (RH-87473)
  • WindowLayout: Rhino does not restore the modified layout (RH-78940)
Rhino 8 SR23 Release Candidate 1 for Windows and Mac (8.23.25224) is now available
Requires Rhino 8
Bugs Fixed:
  • Quad Remesh dialog display scaling issue (RH-88437)
  • BlockEdit: Editing a linked file leaves a "ceflog.txt" file on disk (RH-62888)
  • Curve: Changing active layer while drawing does not update preview color (RH-88368)
  • Display: Selected subobject has clipped selected edge highlight (RH-79197)
  • DotNET: Load MSAL.NET >4.52 for SSO broker support (RH-88608)
  • FilletSrfToRail:
    • failure case (RH-75632)
    • FilletSrfToRail fails to model inward fillet (RH-86204)
    • FilletSrfToRail - trim fails (RH-75734)
  • Group: Only Partial Feedback Hidden Model Layer (RH-88314)
  • LineTypeDisplay: Only Partial Support for RH8 Features (RH-88036)
  • Print: Short Curves Print As Hatch Dots (RH-88367)
  • Properties: Do no assign linetypes from reference files (RH-88743)
  • Rendering: Realtime SDK: Change Queue and Block - Event not fired (RH-88546)
  • Rendering: Textures: ON_Texture simulation has wrong rotation (RH-88633)
  • ScriptEditor: Code wants to compile against specified package versus inspected (RH-88430)
  • SDK: Per-face materials don't work properly with headless Rhino (RH-88227)
  • StatusBar: Units are not displayed as fractional (RH-86734)
  • UserText: Remember Attribute Text key/value column sizes (RH-88503)
Cosmetics:
  • PluginManager: Plug-in's page needs padding (RH-88722)
Crashes Fixed:
  • FilletSrfToRail: crash / hang (RH-86474)
SDK Enhancement:
  • SDK: RhinoCommon: Closed mesh is seen as open mesh (RH-88560)
Mac-Only Changes
Bugs Fixed:
  • WindowLayout: Double OSnap toolbar containers in presets (RH-80062)
Bugs Fixed:
  • UserText: Search Focus Issue (RH-88599)
  • Viewports: Closing Floating View buggers Layout (RH-84419)
Rhino 8 SR23 Release Candidate 2 for Windows and Mac (8.23.25231) is now available
Requires Rhino 8
Bugs Fixed:
  • SDK: CRhinoGetObject and pre-selected instance subobjects (RH-88424)
Rhino 8 SR23 Release Candidate 4 for Windows and Mac (8.23.25241) is now available
Requires Rhino 8
Crashes Fixed:
  • Panels: Import button in Linetypes panel crashes Rhino (RH-89091)
Rhino 8 SR24 Release Candidate 1 for Windows and Mac (8.24.25251) is now available
Requires Rhino 8
Bugs Fixed:
  • Annotation: DimLinear: DimAligned / Dim shifts after changing properties (RH-89220)
  • Annotation: Hatch: Overwriting existing pattern does not update in viewports (RH-88326)
  • BlendSrf:
    • Does not work consistently (RH-89040)
    • Switching on/off internal shapes makes sliver surface (RH-89109)
  • Display: Poorly Visible Curves on Zero-Depth ClippingPlane (RH-83623)
  • ExtendSrf: ExtendSrf_old behaves differently (RH-89006)
  • Grasshopper:
    • Extremes (curve) component doesn’t seem to work right (RH-74711)
    • Pull component should return curve list (RH-89114)
    • Arrow Settings do not get properly serialized/deserialized in GHData In/Out (RH-88819)
    • BoundingBox too small (RH-88798)
  • History: History replay of dimensions when extrusion turns into brep (RH-89215)
  • Revolve: Deformable=Yes creates rotated output (RH-88979)
  • Ribbon: Makes bad geometry (RH-89031)
  • ScriptEditor: Code close does not save to existing storage (RH-89314)
  • Selection: Weird left-click behavior on Mac (previously clicked items remain selected) (RH-89120)
  • Undo: Curve points are deselected after undoing a move (RH-88900)
Crashes Fixed:
  • Grasshopper: Offset Loose component crashes Rhino when connecting Invalid curve (RH-88858)
  • RDKCrash: Content Instance Browser dialog crashes (RH-88897)
Enhancements:
  • HighlightObjectLayers: Should open Layers panel (RH-89079)
Regressions Fixed:
  • UVEditor: Added back ability of copying UV meshes to clipboard (RH-83978)
SDK Enhancement:
  • SDK: RhinoCommon:
    • Exposed CRhinoGet::IsValidOptionName (RH-89300)
    • Exposed MakeUniform command (RH-89160)
UI Change:
  • Grasshopper: SubD turns null when opened in Rhino 7 (RH-88081)
Mac-Only Changes
Bugs Fixed:
  • Annotation: Hatch: Gradient hatch handle not visible (RH-87649)
Bugs Fixed:
  • Rhino Inside: Rhino running headless displays popup about missing fonts (RH-89162)
Rhino 8 SR24 Release Candidate 2 for Windows and Mac (8.24.25273) is now available
Bugs Fixed:
  • InsertEdge: Fails to update Radiate symmetry (RH-82094)
Mac-Only Changes
Bugs Fixed:
  • Settings: Trackpad Settings missing on Tahoe (RH-89545)
Rhino 8 SR24 Release Candidate 3 for Windows and Mac (8.24.25280) is now available
Mac-Only Changes
Bugs Fixed:
  • Properties: Object's Layer Color is Confused (RH-89712)
Rhino 8 SR25 Release Candidate 1 for Windows and Mac (8.25.25287) is now available
Bugs Fixed:
  • Aliases: Mac/Window alias settings are saved in different locations.. (RH-89588)
  • Block: Scaling When Inserted in Detail (RH-89470)
  • BlockEdit: Do not repeat hidden commands in its dialog (RH-89760)
  • Contour: Inconsistent direction of output curves (RH-89376)
  • Displacement: Runs over and over (RH-88735)
  • Display:
    • Technical Display Modes Ignore SubD Display Toggle (RH-78733)
    • Clipping Section Linetype Should Follow Model Space Scale (RH-86187)
    • Objects look inverted when selected (RH-89487)
  • Grasshopper:
    • Updated Sweep 1 Rail component to use Brep.CreateFromSweep method (RH-89549)
    • Unsaved Documents After Saving (RH-89511)
    • Length Factor in Annotation Unit Settings does not get set properly (RH-89467)
  • Import: Suppress package manager dialog (RH-89710)
  • Layer: "Set current layer" icon does not work properly (RH-89447)
  • Offset: Incorrect result for self-intersected region (RH-89462)
  • OSnap: Cannot snap to selected blocks behind shaded objects (RH-89451)
  • Print: Scale of section boundary ignored by vector output (RH-80415)
  • Properties: Changing per-face colors overwrites the object's name (RH-89667)
  • Rendering: Materials: FBX Import Change (RH-89515)
  • ScriptEditor:
    • Inline C# properties do not auto-complete (RH-89648)
    • Project fails to compile when descriptions have new lines (RH-89736)
    • Project fails to compile when there are a lot of string literals (RH-89737)
    • Proxy GetViewList is missing bool,bool overload (RH-89611)
  • SDK: Annotation dots near failing intersection (RH-84286)
  • SDK: Python: rs.PopupMenu error (RH-86577)
  • Selection: Clipping planes can be selected and snapped in display modes that do not display them (RH-89464)
  • ShadeSelected: View manipulation cancels object shading (RH-89463)
  • ShowEdges:
    • Incorrect naked edges shown (RH-89847)
    • Some edges not or hardly visible (RH-89687)
  • Smooth: Needs to remember the dialog location (RH-89645)
  • TextField: PageNumber in model viewports now returns 0 (RH-89428)
  • Toolbar:
    • Unexpected RMB tooltip added to MeshFromPoint button (RH-89629)
    • Removed RMB macros from Layer and Properties buttons (RH-79025)
    • Incorrect macro for LayerBook Print button (RH-89429)
Enhancements:
  • Bake: Added FillRange option for post-selection (RH-89677)
  • EdgeSoftening: Allows more decimals (RH-89753)
Performance Improvements:
  • Grasshopper: Slow down material assignment (RH-89738)
Regressions Fixed:
  • BoundingBox: Extrusion Bounding Box behaviour different in Rhino 7 and Rhino 8 (RH-89799)
SDK Enhancement:
  • SDK:
    • Move SplitRenderMesh to the SDK (RH-89846)
    • Improved input checks for curve intersections (RH-89630)
  • SDK: RhinoCommon: Added a new Curve.TrimInterval which calls ON_Curve::Trim like Rhino_DotNet (RH-89686)
Mac-Only Changes
Bugs Fixed:
  • Properties: Can't change layer of multiple objects at once on Mac (RH-89614)
  • RhinoMonitor: Error report window drifts off screen while resizing (RH-89691)
  • SDK: RhinoCommon: CommandWindowCaptureEnabled not working on macOS (RH-89365)
Bugs Fixed:
  • Toolbar: Loading RUI locks up Rhino (RH-89475)
Rhino 8 SR25 Release Candidate 2 for Windows and Mac (8.25.25294) is now available
Mac-Only Changes
Bugs Fixed:
  • Eto: Eto FileDialog crashes when specifying all files (RH-90064)
  • PackageManager: Install dialog not showing buttons on Mac (RH-89655)
Rhino 8 SR25 Release Candidate 3 for Windows and Mac (8.25.25302) is now available
Bugs Fixed:
  • Layer: Rhino 8 doesn't refresh Layer UI when removing layer material (RH-90141)
Mac-Only Changes
Bugs Fixed:
  • Quicklook: Thumbnail previews not working on macOS Tahoe (RH-90113)
Bugs Fixed:
  • CommandPaste: Paste command should support AutoCAD LT (RH-90097)
Rhino 8 SR26 Release Candidate 1 for Windows and Mac (8.26.25315) is now available
Bugs Fixed:
  • Annotation: Hatch: Hatch display color property missing "By Material" (RH-90331)
  • BlockEdit: Unlock and BlockEdit (RH-52030)
  • Containers: Collapsed Properties Panel Blocks Access to Rhino (RH-82645)
  • CPlane: AutoAlign: Auto CPlane hangs Rhino when subselecting many mesh faces (RH-90290)
  • Grasshopper:
    • Content Note and Tag does not survive GHData serialization on Material (RH-89951)
    • Surface and Curve Orientation are not compared during Content Cache Push operation (RH-89952)
  • Grasshopper: Components: Grasshopper: Rhino 8 GH Extreme component bug (RH-90027)
  • HeightField: Mesh output does not respect active layer (RH-90052)
  • Keyboard Shortcuts: "⌘ + /" Hotkey Keybinding doesn't save (RH-90304)
  • Layer: Restore Print color doesn’t restore synchronization (RH-90172)
  • MeshIntersect:
    • Mesh intersection output going the wrong direction… (RH-67041)
    • SLC export doesn’t work because of mesh intersection changes (RH-66931)
  • Print: Intersections repeatedly added cause printing to freeze (RH-89973)
  • RDK: CRhRdkLongOperation messes up cursor settings (RH-90237)
  • ScriptEditor: Python 3 seems to fail sometimes on matplotlib bootstrap script (RH-90171)
  • SDK: RhinoCommon: InstanceObject.UsesDefinition returns false positives (RH-90174)
  • SelVisible: No Hatch Support (RH-90294)
  • UserText: Options - Document User Text. Preserve Empty Value fields (RH-90302)
  • Display: Lagging with Many Curves (RH-82891)
Regressions Fixed:
  • Properties: Cannot type to find a layer in object properties (RH-89948)
Mac-Only Changes
Bugs Fixed:
  • BlendEdge: Edit BlendEdge set to 0 oblitterates Object (RH-90029)
  • Display: Rendered mode on Mac ignores transparent objects shadow tolerance (RH-89935)
Bugs Fixed:
  • ModifyRadius: Does not accept Enter to keep radius and end command on Windows (RH-90059)
Rhino 8 SR27 Release Candidate 1 for Windows and Mac (8.27.25350) is now available
Bugs Fixed:
  • Annotation: Volume and Curve Length not created on current CPlane (RH-90620)
  • Display: Grasshopper Annotation Dot Disappears in Viewport (RH-89180)
  • File IO:
    • Multi-Page PDF is not Spaced (RH-90871)
    • Rhino missing points from e57 pointcloud (RH-90779)
  • File IO: DWG:
    • Added space after whole number before fraction (RH-90830)
    • Some curves imported at incorrect elevation (RH-90527)
  • Grasshopper: Custom Curve Preview is not calculating the bounding box correctly upon first opening a file (RH-90990)
  • Grasshopper: Components: Sweep1: the sweep surface is not touching the profiles and profiles dont start and end at rail endpoints (RH-91044)
  • LayerStateManager: Layers from linked blocks not restoring properties (RH-90909)
  • Offset:
  • Print: Scripting print doesn't work (RH-90760)
  • ScriptEditor: Project Version can be earlier than previous (RH-90532)
  • SDK: RhinoCommon:
    • RhinoCommon API crashes/exceptions (RH-90896)
    • Added RhinoIntersectPlaneBrep function (RH-90812)
  • Section Style: Error saving section style with hatch pattern (RH-90683)
  • Select: Subobject Left Highlighted After Undo (RH-90624)
  • Trim: Objects with huge bounding box in z-direction are not trimmed properly in layout space (RH-90518)
Cosmetics:
  • Dark Mode: PackageManager install message not theme aware (RH-90433)
Regressions Fixed:
  • File IO: AI file import misses Hatch only objects (RH-85307)
  • Print: Rhino.Options.Advanced.PDF.OptionalContentGroups does not work with Rhino 8 (RH-90679)
Mac-Only Changes
Bugs Fixed:
  • Core Architecture: Improved loading speed for image textures (RH-90913)
  • Dark Mode: Panels don't update (RH-85095)
  • Display Metal:
    • Slower performance in Rhino 8/9 (RH-90576)
    • Objects are displayed dark and dull in Rhino 8 (RH-90853)
  • Grasshopper: OBJ files cannot be written from OSX (RH-90500)
  • Layer:
    • Layer properties cannot be changed sometimes (RH-88035)
    • Cannot rename layers (RH-86220)
  • Print: Vector output to PDF causes a crash (RH-90568)
Crashes Fixed:
  • Eto: Drag and drop material onto object causes a crash (RH-90940)
Bugs Fixed:
  • Containers: Auto-hide right sidebar causes Rhino app to lock up when selecting a mask color for annotation objects (RH-90288)
  • Layer: Layer panel loses focus after sorting a layer with mouse (RH-90476)
Rhino 8 SR27 Release Candidate 2 for Windows and Mac (8.27.25357) is now available
Bugs Fixed:
  • Grasshopper: Components: Annotation Text Override - Wrap Width requires Text Change (RH-90114)
