Rhino 8, Script Editor Creating / Saving Projects Fails on .NetFramework
Hello @eirannejad .
I’m really excited for the scripteditor functionality of creating quick plugins from Python / Gh1.
It seems that I cannot create or save the existing project while I’m in .NetFramework,
while it works flawlessly under .NetCore.
As a Fellow RIR user, I don’t think I’ll switch my rhino to use .NetCore anytime in near future.
Thank you
@tay.othman What errors are you getting when building plugins? Run RhinoCodeLogs to see more about the errors and share that here if you don’t mind. Thank you!
I get the error below:
Below is the Log file
ScriptEditor.txt (17.2 KB)
@tay.othman Seems like there is an issue with the file path. What’s the file name you are trying to save the project as?
Hello @eirannejad . I was not able to start a project at all. And currently I have no open projects.
Okay I’m not following. Would you mind giving the steps to replicate this error so I can investigate the bug?
@eirannejad here is what I’m trying to do.
again, it works fine under. NetCore. this issue is exclusive to .NetFramework.
Oh I see. I can replicate this now. Thanks for reporting and I’ll get it fixed for Tuesday release.
RH-77722 Create project in .NETFramework throws an error
@eirannejad
Hi Ehsan,
I have almost same problem in publishing the project. My error is “Failed getting NETFramework reference assemblies”. Can you help me?
@Hadi_Yazdi
Are you running your rhino instance under . NetFramework or .NetCore?
I tried both. but it didn’t work, same error.
I couldn’t reproduce your issue, can you first try with a simple grasshopper definition. just to make sure it is not caused by a third-party libraries.
I was able to publish it from my side,
@Hadi_Yazdi HI
This is a known issue and I have a ticket for this. Thanks for reporting. I will update when this is fixed
RH-75990 Publishing fails due to missing Newtonsoft.Json
thanks @eirannejad, I follow the discussion
I’m in the same situation as @Hadi_Yazdi.
