I’m not sure if this is an issue with my computer or a bug with Rhino 8 but I’m curious if anyone else has experienced it. Everytime I save a particular file, after the save has completed, I can no longer use my mouse or my keyboard as normal. Everything seems to behave as if the CTRL key is being held down, even though it’s not: the right mouse button will only zoom in and out, hovering over toolbar items shows “Copy Link” text, I can no longer select objects, and typing executes shortcuts instead of typing commands (for example, typing an S in the command line will initiate another save). The really weird thing is that this behavior even extends to other applications, not just rhino. My whole computer behaves as if I am holding down control constantly. The only way I’ve found to get out of it (besides restarting my computer) is to undo the last command. So I can work around it by doing CTRL+Z and then CTRL+Y after every save, but it its still pretty annoying. I’ve attached a quick loom to show what happens:
pls run _SystemInfo in Rhino and post back the results.
Does the same happen if you type _Save (enter)?
Did you try another keyboard?
Here is the result of _SystemInfo:
Rhino 8 SR4 2024-2-13 (Rhino 8, 8.4.24044.15001, Git hash:master @ 5d3f86ffffae3c2ed84d21147c008b3907a40a2e)
License type: Commercial, build 2024-02-13
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.14
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 3090 (NVidia) Memory: 24GB, Driver date: 10-18-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 537.70
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 4.6 (primary GPU's maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 10-18-2023
Driver Version: 31.0.15.3770
Z-Buffer depth: 24 bits
Total Video Memory: 24 GB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp "Commands" 8.4.24044.15001
C:\Program Files\Rhino 8\Plug-ins\rdk.rhp "Renderer Development Kit"
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp "Rhino Render" 8.4.24044.15001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp "RDK_EtoUI" 8.4.24044.15001
C:\Program Files\Rhino 8\Plug-ins\NamedSnapshots.rhp "Snapshots"
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp "MeshCommands" 8.4.24044.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp "RhinoCycles" 8.4.24044.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp "RhinoCodePlugin" 8.4.24044.15001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp "Toolbars" 8.4.24044.15001
C:\Program Files\Rhino 8\Plug-ins\3dxrhino.rhp "3Dconnexion 3D Mouse"
C:\Program Files\Rhino 8\Plug-ins\Displacement.rhp "Displacement"
C:\Program Files\Rhino 8\Plug-ins\SectionTools.rhp "SectionTools"
Strangely it doesn’t happen when I type _Save, only with CTRL+S. I haven’t had a chance to try it with another keyboard but I will try that tomorrow and let you know.
@Gijs Update: I don’t have another keyboard handy to test it, however I tried with the windows on-screen keyboard and got the same result, so it doesn’t seem to be an issue with my keyboard
Ok, disabling and re-enabling PowerToys (which I was using to re-map some keys on my keyboard) seems to have fixed the issue, so I guess it was unrelated to Rhino
