Rhino 8 QuadRemesh Outputs Duplicate Meshes
Recently I noticed that the QuadRemesh command will output duplicate meshes if you select the Preview option. For example:
  1. Draw a cylinder
  2. Run the QuadRemesh command
  3. Tick the Preview option and let it generate
  4. Click Ok
That causes two duplicate meshes to be created as the output.
On the other hand, selecting the Convert to SubD option outputs a single SubD as expected, with or without selecting the Preview option.
Yeah, I noticed this too (old bug), so I never choose preview :face_holding_back_tears:
Thanks I was able to repeat this as well. We will get this patched up in an upcoming v8 service release. Here’s a ticket to follow. https://mcneel.myjetbrains.com/youtrack/issue/RH-84220/QuadRemesh-creates-duplicate-mesh
RH-84220 is fixed in Rhino 8 Service Release 14
