Rhino 8 problem with xref and DWG imports
I am having problems with imports of XREF and DWG files to my Rhino 8.
This import seemed to work OK. I even got a message in the command line saying that the Xref resp DWG files had been successfully imported. I even see the new corresponding layers among my original Rhino layers, BUT I CAN NOT SEE ANYTHING NEW IN ANY OF MAY VIEWPORTS.
I CHECKED THE SCALE OF THE IMPORTS AND THERE SHOULD NOT BE ANY PROBLEMS EITHER. I AM DESPERATE.
PLEASE HELP
TOMAS
Hi Tomas,
I don’t have autocad loaded currently, can you setup a small example? Are the XREF attached or overlays?
Thanks
1st try this: Ctrl+A to select all you’ve imported, then type ‘ZS’ and press Enter to zoom in to selected geometry.
Is there anything selected and visible?!
2nd: Check if the imported layers are visible from Layers tab
3rd: if there wasn’t still anything in sight, the imported dwg can be a damaged or non-uniformly scaled Block or have out-of-tellorance objects inside, try to explode it in Autocad first and then import it to Rhino to see if the problem still exists in order to diagnose better.
Also try different import options specially ‘Natural 2007’ profile since it could help.
