Rhino 8 not working properly in Windows 10
Hello everyone,
I recently upgraded to Rhino 8, and I’m having trouble launching the application. I wonder if this might have something to do with the fact that I’m still running Windows 10 on my PC.
Although Rhino has started and worked normally a few times, most of the time it seems to launch but gets stuck on the screen I’m attaching to this message, displaying the “Not Responding” status. However, I’m able to run it in Safe Mode.
Has anyone experienced a similar issue? Is there any configuration setting I should check or any application I could run to resolve this problem?
Thank you in advance for your help!
Best regards,
Eduardo
Run “_SystemInfo” in Rhino and post the result.
On Safemode (since I was not able to run it normaly):
Rhino 8 SR35 2026-9-8 (Rhino 8, 8.35.26251.13001, Git hash:master @ 3645d710f50175d8ebcf404aded5b042a481c23e)
License type: Educational, build 2026-09-08
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 16GB)
.NET 8.0.14
Computer platform: LAPTOP - Unplugged [72% battery remaining] ~111 minutes left
Primary display and OpenGL: Intel(R) HD Graphics 5500 (Intel) Memory: 1GB, Driver date: 9-29-2016 (M-D-Y). OpenGL Ver: (null)
Integrated graphics device with 3 adapter port(s)
  • Windows Main Display is laptop’s integrated screen or built-in port
Secondary graphics devices.
AMD Radeon R7 M260 (AMD) Memory: 2GB, Driver date: 8-21-2020 (M-D-Y).
Integrated accelerated graphics device (shares primary device ports)
  • This device is not being used
ATTENTION:
Safe Mode is enabled. Graphics device usage and OpenGL information cannot be collected.
OpenGL Settings
Safe mode: On
GPU Tessellation is: On (but disabled due to other settings)
Graphics level being used: OpenGL (null) (primary GPU’s maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Unknown
Render version: (null)
Shading Language: (null)
Driver Date: 8-21-2020
Driver Version: 27.20.1034.6
Maximum Texture size: n/a
Z-Buffer depth: n/a
Maximum Viewport size: 16777472 x 16777216
Total Video Memory: 2 GB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.35.26251.13001
So your video drivers, as you can see, are hopelessly out of date, they need to be updated if newer ones even still exist. Lowering the level of OpenGL acceleration in Rhino’s display properties may also help it work if not well.
dont expect any complex stuff
Thank you very much! That did the trick. I updated the AMD driver ( AMD Radeon™ R7 M260 Drivers and Downloads | Latest Version ), which allowed Rhino to launch, and then lowered the OpenGL 1 setting. Now it’s working fine. It’s not perfect, but it’s good enough (I’d say it’s the best I can get out of this old laptop).
Thanks once again, guys!
