Rhino 8 Mac ScreenCopyToClipboard includes viewport borders
Rhino 8 for Mac is including left, right and bottom borders when using ScreenCopyToClipboard. That does not happen on Windows.
I have looked but not found a setting to prevent this.
MacSystermInfo.txt (4.7 KB)
Regards, Garry.
Update…
With Rhino in Full Screen mode, the borders are not captured.
Regards, Garry.
Hi Garry -
This is from Windows, with the Rhino UI being full screen.
To capture without borders, use ViewCaptureToClipboard
@wim ViewCaptureToClipboard is more clumsy, as it throws a confirmation dialog. However, I have tried both ViewCaptureToClipboard and ScreenCaptureToClipboard this morning, and both provide identical and correct images. The problem seems to have gone away. Not sure whether you noticed it, but the original image above has feint grey borders on 3 edges. The image below is from ScreenCaptureToClipboard this morning. No unwanted edges.
I will mark this as solved, but I do not know how. The Rhino build has not changed. The only thing that comes to mind is that the initial capture was not in full screen, then I discovered that in full screen it was OK. Perhaps the full screen capture reset an internal gremlin. Hard to believe that explanation. I will let you know if there is a recurrence.
Rhino 8 SR14 2024-12-10 (Rhino 8, 8.14.24345.15002, Git hash:master @ cdb74b46090a23fe242c51b288886f76467a741b)
License type: Commercial, build 2024-12-10
License details: Cloud Zoo
Regards, Garry.
