Rhino 8 Layout loss
I’ve encountered a disturbing problem where an R8 file suddenly lost all layouts where I had a number of drawings. I suspect the issue occurred when I had the file open in Rhino 8 for Mac, closed it without saving, and then when I opened the same file in Rhino 8 for Windows, all layout tabs were missing. I saved it in Rhino 7 (to be compatible with colleagues), but I assume it didn’t cause the problem. Has anyone else experienced a similar issue?
Hi @scenografi,
Is this something you can repeat? If so, can we get the offending file along with steps so we can repeat here?
– Dale
Hi Dale
Yes I will try to repeat it tomorrow, keep you informed!
/Fredrik (from Rhino World event)
