Rhino 8: Layer duality
Here is a curious file in Rhino 8.
Using an imported STEP file as a block from McMaster; changing the layer of the block to “Fasteners” takes partial effect, and the bolts exist in a layer duality. Hiding the layer “Fasteners” or the layer “WarningLayer” hides the bolts regardless.
McMasterBlocks.3dm (1.7 MB)
Anyone else see this? I am on 8.2.23346.13001, 2023-12-12.
I’m not bothered really, I can always work around it.
Hi David - the visibility of objects in a block instance is controlled by both the layer of the instance itself and the layers, one or more, of the underlying block definition objects.
Vhttps://wiki.mcneel.com/rhino/usingblocks
In your file, the instances are on Fasteners and the definition geometry on WarningLayer. You can change this in BlockEdit.
That will do me.
Thanks for the explanation!
