Rhino 8 is slow
whatever i do there are 30sec delay. i have never had issue with Rhino 7.
Can you help me?
Key Specifications for Dell XPS 17 9720 (i7 / 32 GB)
Processor (CPU)
  • Intel Core i7-12700H
  • 14 cores, 20 threads
  • Turbo clock: up to ~4.70 GHz
  • Cache: 24 MB
Memory (RAM)
  • 32 GB DDR5, 4800 MHz
  • Configuration: 2 × 16 GB, dual-channel
  • Max supported: 64 GB (2 × 32 GB)
Storage
  • M.2 PCIe NVMe SSD
  • Depending on config: e.g., 1 TB SSD in some models.
  • Two M.2 slots for SSDs according to spec sheet.
Graphics (GPU)
  • Option for NVIDIA GeForce RTX 3060 (6 GB) on some i7 9720 SKUs.
  • Also has integrated Intel graphics (Iris Xe / UHD depending).
Display
  • 17.0″ screen
  • For the 32 GB model, commonly 3840 × 2400 (UHD+, 16:10)
  • Brightness: ~500 nits (for high-res panel)
  • Touch: yes, on some variants.
Ports / Connectivity
  • 4 × Thunderbolt 4 / USB-C (support DisplayPort + Power Delivery)
  • Full-size SD card reader (SD / SDHC / SDXC)
  • 3.5 mm headphone/mic combo jack
  • Kensington lock slot
    Wireless / Networking
  • Wi-Fi: Intel Wi-Fi 6 AX211
  • Bluetooth: v5.2 (according to some sources)
Audio / Camera
  • Webcam: 720p
  • Microphones: 2 × digital-array mics
  • Speakers: Quad speaker system (2 woofers + 2 tweeters)
Power / Battery
  • 97 Wh battery (built-in)
  • Power adapter: Rumoured 130 W for high spec.
Size & Weight
  • Dimensions: ~ 374.5 mm × 248.1 mm × ~19.5 mm
  • Weight: Notebookcheck lists ~2.474 kg for some 32 GB variants
Operating System
  • Ships with Windows 11 (Home or Pro depending on SKU)
Build / Materials
  • CNC-machined aluminum lid (platinum silver)
  • Carbon-fiber composite palm rest (black)
Other Features
  • Memory: Non-ECC DDR5
  • Has 2 M.2 storage slots, so good upgradeability.
  • Security: Wedge lock slot
Please run SystemInfo in Rhino 8 and post the results here. The above info doesn’t actually help much.
