I’m testing fabric models exported as glTF/GLB. The .gltf clearly defines roughness with both a roughnessFactor (0.9–1.0) and a proper metallicRoughnessTexture (PNG, green channel). Example from my file:
"pbrMetallicRoughness": {
"metallicFactor": 0.0,
"roughnessFactor": 1.0,
"metallicRoughnessTexture": { "index": 16, "texCoord": 0 }
The textures are in the same folder as the glTF and load fine in other viewers
. In Rhino 8, however:
The imported Physically Based material shows Roughness = 20% by default.
The roughness texture slot is filled but disabled, so Rhino only uses the scalar 0.2 instead of the file’s 1.0 + map.
Manually enabling the map and setting the slider to 100% produces the correct matte look.
It seems Rhino’s glTF importer is ignoring either the roughnessFactor or the metallicRoughness map, and falls back to 20%.
Can you confirm whether this is a bug in the importer, or if there’s a specific export setting we should be using to get correct roughness values into Rhino? Also, will future Rhino 8 updates improve the glTF/GLB material import handling (roughness/metallic maps, extensions like KHR_texture_transform)?
Thanks!
CAN_1_SEATER.gltf (28.5 KB)
