This seems to be fixed now. All good! Thanks!
Has anybody managed to get the new C# script editor to work with the script
input?
I am not able to get it to print anything in this simple example.
If I remove a trailing semicolon, I get a syntax error, so it seems the script is correctly parsed.
Am I missing something obvious here?
Edit: nevermind, solved (thanks @ale2x72 !)
@ianis.lallemand Currently the ScriptInstance
implementations do not work from input script. I made a ticket to improve this
RH-81986 Support ScriptInstance in input scripts
RH-81587 is fixed in Rhino 8 Service Release 8 Release Candidate 1
Hello
Is the development of the new c# editor dropped?
I see no changes since more than a month ago.
All the points I reported are pretty much the same.
We are at 8.8 and c# code editor is still unusable.
UI, UX and bugs. Nothing is good.
You made coding an awful experience, and new coders will look away instead of dive in.
Please bring back the old editor, it was perfect compared to this.
There is only one single editor for all languages and it is under active bug fixing and improvements.
Both the legacy IronPython and CSharp components are still in grasshopper as hidden components. You can find them by searching as #GHPython
or #C#
in Grasshopper canvas. Create a UserObject from them so theyāre more easily available.
Just to clarify, those legacy components are different in Rhino 8 than they were in Rhino 7 because the old editor controls were replaced with a new one. The editor control on the mac was not the same one as the editor control on windows. The one on windows was a closed source black box that is incompatible with the frameworks in Rhino 8. It was not perfect and keeping it was not an option.
We are aware of the problems with the new editor and like Ehsan says, we are constantly fixing and improving. Some bugs are harder to fix than others and it takes time.
Yeah, I know. Luckily!
I currently make my scripts in Grasshopper in Rhino 7, and the times I try to go to Rhino 8 I simply use them as they are.
But they are completely broken coding-wise. They just execute properly the code, thatās it. But any edit have to be done in Rhino 7.
I would like to test the new āRhinoā tab in grasshopper, but as long the c# editor is not working, that wonāt happen.
(Also, I use c# scripts often to export hundreds of .dxf or .stp files at once, the new āRhinoā tab doesnāt help. Quite delusional.)
Anyway, how many posts with people posting c# snippets you remember to see in this forum, in past?
From David Rutten, Steve Baer, Daniel Piker, Laurent Delrieu, Peter Fotiadis, etc etc etc (too long to mention all the pros) ⦠it was a dream!
The c# script editor was THE perfect playground to quickly make simple codes, to try stuff, to learn! Before going to VS, you could test almost completely anything thanks to the c# editor.
Now? Impossible. Too cumbersome.
How many c# script components from Rhino 8 have you seen here in the forum?
Little to none?
Rhino 8 c# scripts!
Where are those? Where? They shouldāve been a revolution for developers!
Why I havenāt seen a single post in this forum about people using it?
Donāt you think it might be because people gave up trying?
For me, loading a 7 c# script in GH and start it with a button is simpler than having to bear with 8 editor. What a defeat.
Itās incredible we are at SR .8 and this isnāt fixed.
As Rhino is seen as a ādeveloping platformā (or such), this should be in the top 5 priorityā¦
Current Rhino 8 users have 2 broken code editors, the new and the #C#
old one, with no access to Rhino 7, expect new developers to be less than in past.
Instead of a bike, you gave them a unicycle with a flat tire.
Iām sorry but the situation is not really much better than months ago.
I really try.
After 60 seconds you encounter something too bothersome to continue, and give up.
To be clear, the situation should become a āok, now it let me code as fast as in Rhino 7ā ⦠until itās not, people will code in Rhino 7 editor.
There is no ādecent enoughā, particularly after people had access to a better tool.
I totally agree with Riccardo, I mostly use R7 and if I had to use R8 (because of Shrinkwrap mostly) I use the C# editor with Visual Studio open in order to write the code ! And then I include the code in a dll in order to have quite no code to put in R8 C# editor. And I do that because it is a job that requires Shrinkwrap.
@maje90 and @laurent_delrieu what is the first āpainā that we inflict on you when using the V8 editor? Maybe we can prioritize on this.
The āautocompletionā thing.
Extend surface still not a thing in GH, ok, letās do it via c# (my usual short lesson in Gh7).
Too often the editor completely forget you are filling up a method, the method description disappear and, instead, that 200% useless list appears (please get rid of that anywhere).
āthis.ā is not working. RhinoDocument, GrasshopperDocument, Component canāt be accessed.
Similar with external .dll libraries.
The list is long, in my position lot of stuff are needed to have something useable hourS/day.
Edit:
worded that way, actually itās the developers asking once again of what are the problematic points, after I (and others) made multiple lists over time re-reporting the same problems
Once again my thought are āis anyone at mcneel using the tool itself?ā ā¦
No hard feelings. I need to use words as heavy as the situation i see.
Love you guys, I hope for the best.
While I donāt have much experience with C# development in the new editor yet, I too find it unsuitable for IronPython development and largely inferior to GHPython. By order of priority of what is stopping me from using the new editor would be:
Performance: The IronPython script editor is roughly 25-33% slower than GHPython in the tests Iāve done (including real-life project components). And the CPython editor is MUCH slower than GHPython, specifically when implementing RhinoCommon. While the latter is understandable, the former to me is a deal-breaker (as is the situation with the console/terminal). If you can trim the fat, or let the user turn off features that bog down performance (maybe the debugger could be partially responsible), that would would great. Iād expect a new editor to be more performant, not less.
Code legibility: Iām having a harder time reading the text and syntax highlighting than I am in GHPython. I know @Alain is already working in these issues, so hopefully weāll see some improvements there soon.
Design/structure: This was the original intention of this topic. And while there have been great improvements, there are still plenty of remaining issues, which overall make the editor feel quite janky/verbose, and not very balanced, minimal or āzen-likeā, if that makes any sense
I donāt know the insights obviously, so maybe Iām missing something technical-wise and/or buisness-wise, but my opinion is that new editors shouldnāt try to replace old one versions, but be an addition. Same as it is with GH2 now.
Generally from my point of view Rhino 7-8 development decisions regarding direction of new features related to GH are risky, because these are huge UI rewrites (I mean both editors and GH2). Such rewrites even though sound great at the beginning (the thought of new version of GH and new code editors sounds exciting at first) and they seem to make sense (we will do one step back at the beginning, but because of that we will be able to move two steps forward in the future) they often end up as being always one step back, at least this is my experience with code rewrites.
Generally as long as I can easly pick any editor I want to use (old one or new) I donāt see there is a problem. Same with GH, but thatās another topic In short: Iād suggest to change current strategy from rewriting to expanding. Iām more excited about things like Hops, new components from Andy Payne, than these rewrites, even though these rewrites looks better on paper.
Love you guys as well
That would be fantastic!
But, for some reasons they keep saying it is impossible to have the old code editor in 8, so we are left with that broken #c#
editor that is barely a text editor⦠so, to code c# in 8 you are forced to struggle with the new editor.
About autocompletion.
FWIW, it works very similarly to vscode.
But we understand that this is too verbose for many. The autocomplete list is long. If you donāt want to have an autocomplete list while the signature help window is open, the code editor now has an option to turn it off although it hasnāt made itās way to the UI yet. Word based autocomplete, the words that appear in the list by parsing your code, can also be turned off. But our goal is to improve this list, make it smaller and more relevant options at the top. Weāre working on that.
There are events that can cause the method signature window to close like deleting the last brace or having the cursor go past it. You could always pop it back up with shift+ctrl+space
but now typing a coma will also reopen it.
There are many other issues with autocomplete and we are aware of them and doing our best to prioritize and fix them.
Please, give also an option to shut it off completely. That list have to go.
I personally need only to see the current method what and where to put the variables, the descriptions⦠so I donāt have to open the documentation.
Iām on 8.8.24142.13001, 2024-05-21 and
Even adding a space like you did⦠I can see only the dumb list.
You know even microsoft windows have countless shortcuts and key-combo for useless stuff?
Well, most people donāt.
Please make the editor work without having to know hidden key-combo.
⦠not here. Talking about next SR? SRC?
It should be: 1- pressing ESC key or 2- having the cursor outside the ā(ā ā)ā brackets of that method, nothing else. If the method description window close for any other reason, itās a bad UX.
Also, already said, it should drop-down.
Making it go up will cover the code you just wrote, imho itās wrong.
Just try to replicate the good old editor in everything
You mentioned my name and Iām responding to only recent comments. This thread is very long and I know that Ehsan and Alain have been supporting it so I am not completely up to date on all of the details.
I understand, sorry about that.
