Installed the latest update (version in title)
Then opened rhino 8, open grasshopper and it never opens just has the gui /pop up.
then if i run the Grasshopper command again GH opens but nearly half the plugins open
Any ideas?
Hi Peter -
This sounds like an incompatibility with .NET 10. If you change the runtime (SetDotNetRuntime) back to v8, does Grasshopper launch without problems?
If so, you can use the GrasshopperLoadOneByOne command to disable specific 3rd party plug-ins to find out which one is having problems.
So setting .net to v8 works.
Is the plan to transition everything over to v10?
Hi Peter -
I’m not sure what that question means.
.NET 8 and .NET 9 will go end-of-life in November and we made sure that larger organizations can continue using Rhino by making 8.36 and 9.0 run under .NET 10 by default. That part should work fine now.
If, however, “everything” includes all possible 3rd party plug-ins, the answer would be no. We can’t ensure that all developers make their products run under .NET 10.
