Rhino 8 - Ghosted display mode - weird outline around surface edge curves
@Paul_Harris you can test this also side by side, since the changes in NVidia panel need a restart of Rhino. So you can make each instance of Rhino different and compare
See below - default settings on left - adjusted settings on the right.
I should note that I’m running the latest release candidate 8.5 as well.
Ghosted:
Wireframe:
Shaded:
No real difference in any other display modes.
Rhino 8 Test.zip (1.6 MB)
Full resolution Zip of the above screenshots
In that example it might look good, but I found it on default gray and with isocurves on, that the isocurves become fuzzy.
Ah - I see - I don’t usually work with isocurves.
It seems to be working about as good as Rhino 7 does on my machine now:
(Rhino 8 on the Left, Rhino 7 on the Right)
Rhino 8 Test 2.zip (562.9 KB)
It does look good in that screenshot, I’ll have a go at it again.
It looks much better now in (8.6.24086.11001, 2024-03-26).
