For no reason I can think of, it just now worked…
Now it didn’t work
Did a couple more close and reopens, and it is not working unless I delete the Python install and let it run its course again. No idea why it might be failing on the runtime init.
hello.when I write rs.GetObject() on the vscode workplace, no response in rhino windows for me. I do not know whether it is a bug?
Are you running your code from vscode with Run in Rhino
command?
yes, I press F1 in vscode and select run in rhinowip, but no response in rhino command area
just rs.getobject and rs.getobjects no response, other api are normal operation
When I try to run the following Rhino command via rhinocode/python3 with WIP 8.0.22340.12305, 2022-12-06:
import Rhino
rs.Command(‘_About’)
I get the following error:
Info 12/10/2022 11:54:07 PM [RhinoCode] Execute on platform: Rhinocerous 3D @ 8.0.22340 (mcneel.rhino3d.rhino)
Info 12/10/2022 11:54:07 PM [RhinoCode] Execute started
Error 12/10/2022 11:54:07 PM [RhinoCode] Traceback (most recent call last):
File “file:///C:/Users/delf/wip_rhinocode_command_issue.py”, line 3, in
File “C:\Users\delf.rhinocode\python3.9-1.24\site-rhinopython\rhinoscript\application.py”, line 318, in Command
start = Rhino.DocObjects.RhinoObject.NextRuntimeSerialNumber
NameError: name ‘Rhino’ is not defined
Info 12/10/2022 11:54:07 PM [RhinoCode] Execute ended
Info 12/10/2022 11:54:07 PM [RhinoCode] [pyminilsp] INFO - request to diagnose C:\Users\delf.rhinocode\stage\ycyagezz.nzv
Info 12/10/2022 11:54:07 PM [RhinoCode] [pyminilsp] INFO - checks complete
It looks like the Rhino module is not being properly imported for rhinopython’s application.py. Does anyone else have this problem?
Look Ironpython 3 is now out !
When I tried to open the RhinoCode editor RhinoWIP immediately crashed. And later I tried GHPython it crashed too. I’m using the latest version(8.0 (8.0.22347.14306)) and macOS 13.0 (22A380).
The error message is below. Might be something to do with a js framework for text editor?
log.txt (122.0 KB)
[ERROR] FATAL UNHANDLED EXCEPTION: System.AggregateException: One or more errors occurred. (Error Domain=WKErrorDomain Code=4 "A JavaScript exception occurred" UserInfo={WKJavaScriptExceptionLineNumber=1, WKJavaScriptExceptionMessage=ReferenceError: Can't find variable: ed, WKJavaScriptExceptionColumnNumber=3, WKJavaScriptExceptionSourceURL=ed:///EdCoreAssembly/js/dist/index.html, NSLocalizedDescription=A JavaScript exception occurred})
Full error log in linked file.
Thanks. It is fixed and is available in latest WIP build
Hello, this’s a amazing work. How can I use ghenv.Component in RhinoCode? I want to write a scripts like this ExpireSolution in GhPython, but it shows “ghenv not defined”. Looking forward to your reply, Thanks!
from scriptcontext import sticky
thisDoc = ghenv.Component.OnPingDocument()
slider = ghenv.Component.Params.Input[0].Sources[0]
if click_me:
# reset values to starting position
sticky['running'] = True
slider.TickValue = 30
desired_area = 12
if sticky['running']:
if area > desired_area or slider.TickValue >= slider.TickCount:
sticky['running'] = False # break the loop
else:
def sln_delegate(doc):
slider.TickValue +=1
thisDoc.ScheduleSolution(1, sln_delegate) # call the delegate function and schedule a solution in 1 millisecond
Hi Ehsan, I am so grateful for being able to code in Python3 and being able to install different libraries. For me that’s a 10 year long wish come true, so thank you!
I do have a few wishes for RhinoCode that would speed up my workflow:
- let RhinoCode print to CommandLine while the script is ran. Right now print(“”) just prints to the Terminal after the script is completed. I see that rs.Prompt() works fine now, thanks for that!
- Reset the prompt to “Command:” after a script is completed, now it stays on the last prompt provided.
- have rhinoscriptsyntax autocomplete (better) like it does in Rhino Python Editor.
- Being able to scroll the Terminal content sideways
- Have an autosave on run option, just like the Python Editor does. (old habits are difficult to change, so maybe have this as an option in Preferences)
- Edit: And keep track of it’s own last used folders for open/save. (Now if I open a Rhino file then RhinoCode also uses that folder when the save/open dialog pops up, and not the folder RhinoCode used last)
And of course be able to run Python 3 scripts from buttons. And compile them to plugins, but from a button is first priority for me personally.
Thanks for listening and for the amazing work you have done!
@Holo This is a great list! Thank you so much.
I added these YTs in order of your bullet points:
Hi @eirannejad,
great work! However I get “Unknown command: Rhinocode”. Has the command been removed again?
Thanks,
Tim
Hi Tim -
This is now called ScriptEditor
Great! thanks @wim
hi
i’m on an m1 mac, latest wip
when i enter scripteditor, it opens but i cant interact w/ anything
all menu items are greyed out too—only button that works is ‘rhinocode logs’ which displays this:
this is the first time i’ve tried to run the script editor.
any help is appreciated
Hi -
I’m seeing that here as well.
Reported as RH-73170 RhinoCode: ScriptEditor is inactive
