Windows 10.0.19043 SR0.0 or greater (Physical RAM: 32Gb)
Primary display and OpenGL: NVIDIA Quadro RTX 3000 (NVidia) Memory: 6GB, Driver date: 10-26-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 472.47
Secondary graphics devices.
Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 11-2-2021 (M-D-Y).
- There are no monitors attached to this device. Laptop lid is probably closed
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 10-26-2021
Driver Version: 30.0.14.7247
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoCode\RhinoRoslyn.rhp “RhinoRoslyn” 8.0.21327.16305
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.0.21327.16305
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoCode\RhinoCPython.rhp “RhinoCPython” 8.0.21327.16305
C:\Users\silvano\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\ColorPicker\6.0.0\ColorPicker.rhp “ColorPicker”
C:\Users\silvano\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\ggRhinoIFC\2.1.23.0\ggRhinoIFC.rhp “ggRhinoIFC” 2.1.23.0
C:\Users\silvano\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\rhinopbrmaterial\1.1.4+v6.16\RhinoPbrMaterial.rhp “RhinoPbrMaterial” 1.1.2.0
A miniature view of the code is shown on the far right instead of just a scrolling bar. This seems like an easier way to navigate up and down in the code.
How can I change my GH Python editor to the Rhino code editor, It still use the original python editor in RhinoWIP 8 and many classes are missing. for example when I type ‘from System import Uri’ I can run it in the Rhino Code edit. But in the original python editor, it will return an error that says cannot import the name Uri. Do you know the reason? is it because it’s using a different version of Python?
@user2234 RhinoCode editor is still not available for Grasshopper. We are working on it though. I don’t see any problems with from System import Uri in the original python editor. The original editor is running IronPython which is a different implementation of python and follows the python 2 specification. The new RhinCode editor ships with CPython 3
Hi @eirannejad ,
Will Cpython 3 be available through a separate Grasshopper GHPython component?
I am just confused how the GHPython component which supports IronPython 2 will relate to that future GHPython Cpython 3?
I just discovered this thread, if I understood correctly, the RhinoCode editor is an HTML control in which you have integrated Monaco.
So I’m assuming you’re making RPC-like calls between Rhino and RhinoCode.
If so, it might be useful to expose a public API to make these calls.
The goal would be to be able to connect Rhino to external editors.
I understand the usefulness of having an IDE built into Rhino and why some users need it.
An IDE is complex software. There comes a time when you want to work with your own editor.
In terms of debugging it seems to me that the license of the Python server of VSCode will not allow to integrate debugging in the editor.
A few years ago, I experimented with C# scripting when Roslyn was released. GitHub - corbane/Ghx: Debugging Roslyn script inside Grasshopper. (This is a proof of concept, which should no longer be compatible with VSCode.)
Connecting Rhino to an external editor will also debug CSharp scripts.
There is no need for a language server here, just portable x64 PDBs and source files accessible on the file system.
excited for this new python version!
When i install numpy by pip i meet a basic problem (sorry i am not a computer expert). Even i add ‘…rhinocode\python3.9-1.11’ and ‘…rhinocode\python3.9-1.11\scripts’ into my PATH, it still returns pip and python are not there, so that i can’t install numpy. It seems it always recognize my pip from another folder belongs to anaconda.
I don’t know how to successfully install python3,pip,numpy into rhino script based on existing python from conda. Any simple solutions?
Published RhinoCode for Visual Studio Code RH-66659
Major improvements on the inner-workings of the code editor. The is only one file now storing all code editor settings and states ~/.rhinocode/editor.json
Do you plan any debugging tools, internal to RhinoCode or via an external editor ?
I am not a developer, I am a modeler, those before digital (it’s closer to the carpenter).
But today everything is digital, so I learned to adapt Rhino to my needs and I have a more successful version of my previous experimentation.
I’m happy, it works with Rhino7 and Rhino8.
My code is embedded in a library that I cannot share.
When I see your code and mine it doesn’t seem like we have the same approach,
but if it helps I can extract a small version of this plugin ?
What you take care of, I won’t have to do it anymore.
