I have recently upgraded my system a now operating through a PC instead a Mac. As it was a built PC, I am still unsure if my Rhino settings and preferences are set correctly on this new computer, as Apple seemed to have my settings correct form the get go. It is all quite laggy and even have trouble opening a layout tab as it will just freeze and autosave, even with one detail view.
I have looked through past discussions so have posted my system information below if that is helpful.
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 64GB)
.NET 8.0.14
Windows Main Display attached to adapter port 0
Primary OpenGL: NVIDIA GeForce RTX 5060 Ti (NVidia) Memory: 16GB, Driver date: 10-9-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 581.57
Accelerated graphics device with 4 adapter port(s)
There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 10-9-2025
Driver Version: 32.0.15.8157
Z-Buffer depth: 24 bits
Total Video Memory: 16311 MB
My files seem to be fine for a few days then they become quite slow, especially when starting layouts. I have tried all the tricks: purge, SalBadObjects, turning my detail views to wireframe only. My files at the moment aren’t over 500MB and with one layout, so its quite confusing that I’m experiencing these issues on a stronger PC with basic models.
This gives the story. According to this systeminfo snapshot you could have saved a bundle of money on that nvidia card because it isn’t being used at all.
Since it’s a desktop I believe that the Intel graphics output connector is separate from the ones on the Nvidia card. Could it be that you have your monitor plugged into the wrong video output?
On hybrid video laptops and notebooks I think the video card choice is done in configuration software so Japhy’s link would definitely apply, but for a desktop with separate connectors I’m not sure.
Also, the Nvidia driver is from early October, and while this should be OK for Rhino you might check the Nvidia driver download site for a later one.
To add on to AIW’s advice, on a PC the NVIDIA graphics will be on a separate “card” which has several video connectors on the rear of the box. The Intel graphics are the motherboard and the video connector will be on a panel at the rear of the box which also has audio sockets and USB sockets, and possibly others.
