I have a design I like to apply section view per layer on. The design has various subcomponents and each assigned to a separate layer. I have selected cross section per layer.
Section 0 is top lid of the design, section 2 is a plastic support part, section 3 is a circuit board and so on.
I have successfully configured these section view and by moving them I can peel of various parts of the design and reveal details to be worked on. It is one problem though - when I successfully peel of the top layer (witch is a polysurface) and start to peel the second layer - the first layer section cut is going off and the top part then obscure the view when trying to position the second section view.
Unfortunately, I cannot share the design and I have made a dummy test to try to replicate the problem. First, I could not replicate the problem by making a test on simple boxes. The section view worked as expected. But adding a polyline some how trigged the unwanted behaviour. When the polysurface was deleted, the problem stayed the same.
The two images below try to explain the problem.
I like to add that the initial design file (the one I cannot share) was first processed (step import) in Rhino 8 for Win 10 then closed and reopened on my Mac.
Any one else that has observed this behaviour? It could be that I have missed a setting or two and that this could solve the problem.
