Rhino 8 CTRL gumball rotate
Howdy
With rhino 7, you could rotate the gubal but holding CTRL and swinging it around… with rhino 8 it doesnt seem to do it.
Has the command changed?
Hi Yolanda - try a double-click on the Gumball arc handles - or any of the handles. This allows re-positioning the gumball.
I use cross gems as a plug in - this is a problem because when im using a cross gems object and i double click on the gumball it just opens the object in the toolbox panel
