Hi !
I didn’t find a similar topic so I’m opening a new one.
I am using pip packages such as open3d to make operations that are not included in RhinoCommon, such as ICP point cloud registration. In may of this year I am certain calling the open3d ICP registration worked fine (probably using some version of Rhino 8.7, possibly 8.6) on MacOs.
Fast-forward to today, using rhino 8.9.24194.18122 on MacOs, as well as 8.8.24170.13001 on Windows, the code that previously worked now crashes, and the new code I am currently developing does it as well.
The issue is directly linked to specific lines of code involving open3d, but not all. For example, creating an open3d PointCloud object works fine:
def align_to_skeleton(self, reference_skeleton):
Align the tree to a reference skeleton using ICP
:param reference_skeleton: Pointcloud
The reference skeleton to align to
tree_pc = o3d.geometry.PointCloud()
tree_pc.points = o3d.utility.Vector3dVector(np.array(self.point_cloud.points))
skeleton_pc = o3d.geometry.PointCloud()
skeleton_pc.points = o3d.utility.Vector3dVector(np.array(self.skeleton.points))
skeleton_pc.estimate_normals()
reference_skeleton_pc = o3d.geometry.PointCloud()
reference_skeleton_pc.points = o3d.utility.Vector3dVector(np.array(reference_skeleton.points))
reference_skeleton_pc.estimate_normals()
print("Tree point cloud has ", len(tree_pc.points), " points")
print("Skeleton point cloud has ", len(skeleton_pc.points), " points")
print("Reference point cloud has ", len(reference_skeleton_pc.points), " points")
print("tree_pc is of type: ", type(tree_pc))
print("skeleton_pc is of type: ", type(skeleton_pc))
print("reference_pc is of type: ", type(reference_skeleton_pc))
initial_translation = np.identity(4)
initial_translation[0, 3] = reference_skeleton_pc.points[0][0] - skeleton_pc.points[0][0]
initial_translation[1, 3] = reference_skeleton_pc.points[0][1] - skeleton_pc.points[0][1]
initial_translation[2, 3] = reference_skeleton_pc.points[0][2] - skeleton_pc.points[0][2]
# result = o3d.pipelines.registration.registration_icp(skeleton_pc,
# reference_pc,
# 10.0,
# initial_translation)
terminal output:
Path of script to run ( Browse ): /c:/Users/localuser/Carnutes/src/function_3.py
Select the whole structure
Select the whole structure. Press Enter when done
Curves converted to NurbsCurve
Select the element to replace with a point cloud
Element selected: fc65a236-6eec-42b4-97a9-04bd30dc6829
Tree 6 - 4901
Tree point cloud has 4902 points
Skeleton point cloud has 11 points
reference skeleton point cloud has 31 points
tree_pc is of type: <class 'open3d.cpu.pybind.geometry.PointCloud'>
skeleton_pc is of type: <class 'open3d.cpu.pybind.geometry.PointCloud'>
reference_skeleton_pc is of type: <class 'open3d.cpu.pybind.geometry.PointCloud'>
Done
but as soon as I call the ICP registration (the line commented-out in the code above), Rhino crashes altogether. On windows it freezes 2-3 seconds, on MacOs it is instantaneous. Where it gets very strange, is that using RANSAC based on feature matching doesn’t crash, but if I try to print the resulting transformation matrix, I get a strange error:
result
= o3d.pipelines.registration.registration_ransac_based_on_feature_matching(skeleton_pc, reference_pc, skeleton_pc_fpfh, reference_pc_fpfh, False, 10.0)
transformation
= result.transformation
tree_pc = copy.deepcopy(tree_pc)
print("Type of transformation matrix: ",
type(transformation))
print("Shape of transformation matrix: ",
transformation.shape)
print("Transformation matrix\n",
transformation)
terminal output:
Path of script to run ( Browse )/Users/admin/Carnutes/src/function_3.py
LineCurves converted to NurbsCurves
Element selected: 6ccc6e76-5267-452b-b012-07ab5a5fe95c
Tree 4 - 3315
Type of transformation matrix: <class 'numpy.ndarray'>
Shape of transformation matrix: (4, 4)
Traceback (most recent call last):
File "file:///Users/admin/Carnutes/src/function_3.py", line 99, in <module>
File "file:///Users/admin/Carnutes/src/function_3.py", line 96, in main
File "/Users/admin/Carnutes/src/utils/tree.py", line 113, in align_to_skeleton
print("Transformation matrix\n", transformation)
File "/Users/admin/.rhinocode/py39-rh8/site-envs/default-ipRe2pAH/numpy/_core/arrayprint.py", line 1664, in _array_str_implementation
return array2string(a, max_line_width, precision, suppress_small, ' ', "")
File "/Users/admin/.rhinocode/py39-rh8/site-envs/default-ipRe2pAH/numpy/_core/arrayprint.py", line 757, in array2string
return _array2string(a, options, separator, prefix)
File "/Users/admin/.rhinocode/py39-rh8/site-envs/default-ipRe2pAH/numpy/_core/arrayprint.py", line 529, in wrapper
return f(self, *args, **kwargs)
File "/Users/admin/.rhinocode/py39-rh8/site-envs/default-ipRe2pAH/numpy/_core/arrayprint.py", line 555, in _array2string
format_function = _get_format_function(data, **options)
File "/Users/admin/.rhinocode/py39-rh8/site-envs/default-ipRe2pAH/numpy/_core/arrayprint.py", line 488, in _get_format_function
return formatdict['float']()
File "/Users/admin/.rhinocode/py39-rh8/site-envs/default-ipRe2pAH/numpy/_core/arrayprint.py", line 427, in <lambda>
'float': lambda: FloatingFormat(
File "/Users/admin/.rhinocode/py39-rh8/site-envs/default-ipRe2pAH/numpy/_core/arrayprint.py", line 959, in __init__
self.fillFormat(data)
File "/Users/admin/.rhinocode/py39-rh8/site-envs/default-ipRe2pAH/numpy/_core/arrayprint.py", line 970, in fillFormat
with errstate(over='ignore'): # division can overflow
File "/Users/admin/.rhinocode/py39-rh8/site-envs/default-ipRe2pAH/numpy/_core/_ufunc_config.py", line 419, in __enter__
extobj = _make_extobj(
TypeError: python object must be callable or have a callable write method
The numpy and open3d issues might not be related, but they appeared around the same time, so maybe they are a more general issues with pip packages ?
Here is my system info of Windows:
Rhino_sys_info_Windows_Damien_Gilliard.txt (2.5 KB)
Here is my system info of MacOs
Rhino_sys_info_Mac_Damien_Gilliard.txt (4.2 KB)
on windows I don’t get any crash report, but on mac I get this:
error_report_Damien_Gilliard.txt (335.7 KB)
Since The code is on Github, to reproduce the error, I believe the most simple is to clone the Model_connectivity branch of the Carnutes repository and run the function_3.py with Rhino’s ScriptEditor. This repo is Work In Progress, but for the rest works fine.
If the issue is caused by an error of mine, I apologize in advance, and if not, I hope this Topic can improve future versions of Rhino8.
Thanks in advance !!
