I just installed VA 3 Beta and Rhino crashes at opening. I followed the install instructions and remove previous versions of VA 2. Rhino 8 is running SR 3 and uses Core.NET.
Opening Rhino 8 via the VA desktop shortcut, Rhino just crushes after the first use plugin window appears. I still can open files that contain VA objects via the use of Rhino 8 (standard shortcut). But the VA desktop shortcut just makes Rhino to crash.
Do you have your Rhino 8 set to use the .NET Core Runtime? VisualARQ still requires the legacy .NET Framework. We have received some reports from a crash when .NET core is selected.
I’m currently working on a quick fix that will be released later today. The following VisualARQ features will require to change Rhino to use .NET Framework:
Grasshopper Components
Grasshopper Styles
Script API
We will add support for .NET Core before the final release.
In order to change the .NET Runtime, just run the command SetDotNetRuntime and select “.NET Framework”. You may need to run Rhino 8 in Safe Mode.
There are no known downsides, unless you have specific plugins that require different runtimes, then, it is not possible to have all plugins working in the same instance.
We will add support for .NET Core soon, before VisualARQ 3 ships.
In the last VisualARQ 3 beta, VisualARQ will load correctly even when Rhino 8 uses .NET Core, but a warning message will be shown, and some features will be disabled:
Grasshopper Styles
VisualARQ Script API
You can change Rhino 8 runtime as many times as you want. This doesn’t affect 3DM files.
Hi Miguel, does it crash when doing any specific operation? do you get a crashdump file on your desktop when you experience that crash? if you do, please rename that file before closing the Rhino Crash message. Then zip it and send it to us (visualarq@asuni.com).
Hi, I made the change to the NET Framework and it worked fine, but I installed the new LANDS DESIGN and it doesn’t work anymore, even after I canceled the installation. what do we do with it? I can’t work with VISUALARQ at all now, it just crashes
Hi @11170 As per Lands design support team , they are still working on compatibility between LD 6 and VA3. You just uninstalll both and reinstall VA3 fo now. It worked for me. It will take a week for them to solve it.
We have discovered an incompatibility between the currently published VisualARQ 3 Beta and Lands Design Pre-Release. We’re going to publish updated versions of both plugins tomorrow.
You no longer need to change .NET Runtime to “.NET Framework” in order to run VisualARQ 3 or Lands 6, as this crash was fixed some weeks ago. “.NET Core” is fully supported now.
