Objects in this file will crash the rhino 8 in the latest SR without report when being queried in Grasshopper. This situation appeared after I change the usertext by bake itself.
Please see below:
If you do audit you’ll there is an issue with the Render material on the objects. Putting a new material on the objects allows them to be used in GH again.
Interesting, another thing of note is I was able to submit a crash report (MacOS), where yours did not. Regardless, its in the system and being looked at. Thanks for reporting,
