Rhino 8 Clipping Sections Named View - fine tune please
Named View resulting from Clipping Sections should match the bounding box of the geometry selected. Right now it is set on a small arbitrary region.
Yes, this is totally happening. I section a 30m building and the Named View generated is just a small 1m area.
Hi Bogdan - I see that, thanks.
RH-81194 Clipping sections named view
The best Clipping Box is in Revit.
A box which can be adjusted by dragging every side of the box, using the mouse.
The geometry inside gets sectioned with a pattern, and depending on the orientation a Make2D group is made with the geometry inside the box.
But Revit also has smart objects. For example:
An adaptive block with 3D geometry, like a chair or a table, has inside it the 2D representation to be used in a 2D drawing.
