Greetings,
I noticed that geometry from Clipping Plane Sections is grouped toghether with the 3D geometry that has been Sectioned - In case when the initial Sectioned geometry is Grouped.
Small bug in such a great tool!
Greetings,
This bug in combination with Clipping Sections creates a horrible mess of Groups containing 2D elements from the section and 3D elements from the inital sectioned model.
Elements that are hard to notice, groups that are hard to understand and select because they span on different types of drawings.
Please fix
I see it. You are using ExtractClippingSections command with Group=Yes.
Added to the pile…
Thank you so much for looking into this. I have to constantly UngroupAll and cannot keep groups well organized.
ExtractClippingSections with Group=Yes creates an initial group and then every 3D group inside this main group includes the 2D elements also.
Please fix this. Like I said before, It is very inconvenient to have 3D geometry grouped toghether with the 2D gemetry resulting from Extract Clipping Section.
Hi -
I’ve reopened RH-81221 ExtractClippingSections: Sectioned objects incorrectly added to output group
