Rhino 8 cannot open the file
Recently, I used rhino 8 for modeling tasks. In the process, Visual Arq beta was used for modeling, and I tried to test other models modeled using this plug-in, and it opened normally. The following file is I have no way to open, I can not find any reason, help!!
家装.3dm (4.9 MB)
No issues opening the file here.
If you start Rhino in Safe Mode (via Windows Start) can you open the file?
Please run SystemInfo in your command line and post the result. Thanks.
First of all, thank you for your help. After providing ideas. I found that after disabling this beta plugin, I was able to open the file normally. Thanks again.
