at around 1 minute mark, you can see i was trying to turn the Layer “0“ on, but it doesn’t get turned on. Some objects flashes up but they disappear again.
I can PM you the source file.
How to reproduce:
Create a new file
import the file
try turning on Layer “0”
System Info below.
Rhino 8 SR23 2025-9-8 (Rhino 8, 8.23.25251.13001, Git hash:master @ e75a9d62e23cc6f52d4ef68eb7eda9f8da9b6cd9)
License type: Commercial, build 2025-09-08
License details: Cloud ZooWindows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 64GB)
.NET 8.0.23Computer platform: LAPTOP - Plugged in [100% battery remaining]
Primary display: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 2GB, Driver date: 11-3-2025 (M-D-Y).Integrated graphics device with 4 adapter port(s)
- Secondary monitor attached to adapter port 1
Primary OpenGL: NVIDIA RTX 5000 Ada Generation Laptop GPU (NVidia) Memory: 16GB, Driver date: 10-12-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 581.60Integrated accelerated graphics device with 4 adapter port(s)
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Graphics level being used: OpenGL 4.6 (primary GPU’s maximum)Anti-alias mode: 4x
Mip Map Filtering: Linear
Anisotropic Filtering Mode: HighVendor Name: NVIDIA Corporation
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 10-12-2025
Driver Version: 32.0.15.8160
Z-Buffer depth: 24 bits
Total Video Memory: 16376 MBRhino plugins that do not ship with Rhino
C:\Users\Wileyng\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\Terra\1.1.10\net7.0-windows\Terra.rhp “Terra” 1.1.9.0
C:\Program Files\Enscape\Enscape.Rhino.Plugin-net48\Enscape.Rhino8.Plugin.dll “Enscape.Rhino8.Plugin” 4.8.0.723Rhino plugins that ship with Rhino
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.23.25251.13001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.23.25251.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.23.25251.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.23.25251.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.23.25251.13001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.23.25251.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.23.25251.13001
C:\Program Files\Rhino 8\Plug-ins\BlockEdit.rhp “BlockEdit” 8.23.25251.13001
