Rhino 8 Bug, Split by IPlane
!_Split _Pause IP _Vertical _Pause _Pause _Enter
The run failed
Hi -
That works fine here:
Please post a 3dm file that you are having issues with.
Also, please run the Rhino SystemInfo command and copy-paste the result here.
When you select the Chinese version, it doesn’t work,
When switching to the English version, it can be run
微信图片_20231216081015
Just in case - this is not quite right, there needs to be a space after !
! _Split _Pause IP _Vertical _Pause _Pause _Enter
I don’t know if IP also may need an underscore >>> _IP
@jessesn - can you test this?
在 Rhino 8 中请使用下面的 Macro,
! _Split _Pause _InfinitePlane _Vertical _Pause _Pause _Enter
Split_IP_R8_Issue
I found the same issue about IP with @SONG1 in Rhino 8, and I made an YT for it.
Successfully run, thanks
