I cannot get the Ensure method of the User Text component to work for the life of me.
It always overwrites the User Text Value.
On your end does it work correctly?
My expectation/workflow is the following:
-Create a new “object” and assign default parameters and bake to document (example here “Room Center Points”)
Establish Default Parameters:
Create a text entity with the Room Name Value as the Text:
Bake Text Entity Room Tag to new layer:
Bake Success:
Post Initial Bake after changing another room tag Room Name value (Also Succeeds):
However, when I make a change such as moving a room division line/wall (which would update the location of the room center point) the values of the Room Tags/User Text return to the defaults despite “Ensure” being enabled.
I was able to “catch” the Bake Content component expiring the Query Model Objects component. Is this what is breaking the reference chain?
In my mind how I have it set up should be working but either it’s bugged or a user error on my end that I cannot figure out.
Thank you for your help!
